Old 08-17-2011, 09:25 PM
rjk8807 rjk8807 is offline
Wheel squeaks when turning right, 2003 grand am help***!
I just got my brakes replaced about a month ago, but now my front driver-side wheel makes a squealing sound when i turn to the right (only to the right). it sounds faster when i am moving faster, for example longer squeaks for fewer wheel revolutions. what could it be? Thanks for your help!
Old 08-18-2011, 09:39 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Wheel squeaks when turning right, 2003 grand am help***!
Welcome to AF!!
Pull the wheel and check to see if anything is making contact with the rotor or the caliper. There is a possibility that the pad has slipped and is shifting and contacting the rotor when you turn right. Also check to see if the caliper bolts are tight.
The other possible issue is that the wheel bearing is going bad. If you hear the noise if you move the steering wheel only slightly I would believe that the bearing may have an issue. Otherwise concentrate on the brake and its components.
Old 08-20-2011, 01:23 PM
Tech II Tech II is offline
Check the backing plate to see if it's contacting the rotor....
Steering wheel squeak when turning.... Glen_T Camry/Camry Hybrid/Vista 11 05-26-2014 11:06 PM
Squeaking when turn right muddypuppy Tahoe 1 08-06-2005 10:53 PM
1999 Corolla Squeaks when turning right belgichocolate Corolla/Matrix/Voltz 1 10-14-2004 04:31 PM
98 Blazer Squeaks when turning right RaI3id_Squirrel Blazer 0 09-23-2004 10:44 AM
Squeak when Turning Right!!! FrancoT Aurora 20 05-19-2004 07:45 AM
