Old 08-17-2011, 10:34 AM
greer13 greer13 is offline
1998 Jimmy 4WD Problem
Hi - there is a loud whirring noise about 25-30 mph and you can feel vibration under drivers side floor board and the truck just seems to drag when foot is off gas it just seems like its stuck in 4 wheel drive it doesn’t matter if button is in 2hi or 4hi the actuator under battery tray is compressed which I understand is that 4WD is engaged. Also to get the switch to light up in 4hi you have to hold it for about 5 seconds.
These are some of the things I tried....
- I disconnected the vacuum hose and cable from actuator under battery tray, plugged vacuum hose, the actuator uncompresses and the cable will move in and out about an inch or so pushed it in and drove truck no change.
- I tested the voltage at the plug at transfer case and it was around 12 volts
- with the front wheels off the ground, if I turn one wheel and the other wheel did not turn, so now I am confused I thought the other wheel should turn the opposite way if engaged.
Any help or suggestions will be appreciated.
Thanks
Chris
2001 Rodeo 4wd problems Derman Rodeo | Passport | MU 2 01-20-2010 07:49 PM
1998 Jimmy - 4WD selector switch - no lights CDJimmy Jimmy 2 02-27-2005 07:45 PM
94 Jimmy 4wd Problems ma3w Jimmy 2 12-20-2004 09:20 AM
97 Jimmy 4WD Problem Greedfly13 Jimmy 3 08-18-2004 03:45 AM
97 Jimmy 4WD Problem Greedfly13 Blazer 4 01-08-2004 08:00 AM
