Old 08-17-2011, 02:22 AM
barker23 barker23 is offline
Send a message via Yahoo to barker23
Need help with 03 TB/LT/EXT Front axle/diff
Been hearing noise from front end, finally today pulled off passenger tire and noticed where the axle goes into pan, it was all shinny, so I reached in and the axle shaft can be moved around alot.
I do most of my own mechanical work, but have never worked on a 4x4 with this type of differential. Is it bearings, seals bad? Can anyone tell me what it takes to fix this?
Thanks
03 Chevy Trailblazer LT EXT
04 Silverado Z71
88 Fiero Formula V-6
82 Chevy Corvette
07 Dodge Caliber
Old 08-17-2011, 08:57 AM
Schurkey Schurkey is offline
Re: Need help with 03 TB/LT/EXT Front axle/diff
Thanks
From another thread:
http://www.automotiveforums.com/vbul....php?t=1069075
Originally Posted by Schurkey View Post
If it's a 4X4, you can pretty much expect to have to replace/rebuild the actuator bolted to the side of the engine oil pan.
The gears and bearings inside are a known trouble spot. Initial symptoms are whine/growl especially when in 4 wheel drive; sometimes with much reduced whine/growl when in Automatic 4 wheel drive but not completely engaged.
The typical "fix" is to buy a rebuilt unit, and simply switch the defective one for the rebuilt one. I think the replacement cost me about $425 two years ago; and I installed it myself. Prying the old one out of the oil pan is the worst part of the job. It's a loose "press fit", but the two aluminum parts corrode together and become a bitch to separate.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 08-17-2011, 10:38 AM
Schurkey,
Does the actuator have anything to do with the axle moving around? Or will it need rebuilt along with replacing the axle bearings and seals in the pan?
Im not sure what the actuator does. I know the 4 wheel drive will kick in and works.
04 Silverado Z71
82 Chevy Corvette
07 Dodge Caliber
Old 08-17-2011, 04:45 PM
Schurkey,
Likely.
There are no bearings and seals in the pan. There is a "gearbox" that bolts TO the pan on the passenger side. That's the weak spot. When I replaced mine, I tore the old one apart. There was a "gear" that had a machined bearing surface on it, and the bearing surface was torn up along with the bearing being defective. The axle shaft itself was/is fine.
The actuator connects the axle shaft to the front differential. If it stayed engaged, the front wheels would drive the differential, if it failed to engage the differential could not drive the front wheels.
Between that actuator and the clutch in the transfer case, the 4WD can be on, off, or "ready" to be engaged automatically if needed.
idk if i have this in the right spot oh will need help with a project mika3585 Engineering/ Technical 6 08-20-2011 11:31 PM
Need Help With noise comin from front wheel jubsveedub Cavalier Problem Diagnosis 1 12-10-2008 12:07 AM
need help with removal of drivers side axle signtech909 Sephia 1 10-21-2007 06:17 PM
installed ram jet in 91 camaro need help with proper exhaust and front accessories spankincamarors F-Body Problem Diagnosis 0 07-03-2007 10:37 AM
need help with 95 LT 4x4 jetblack style Blazer 5 01-18-2005 01:59 AM
