Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-16-2011, 07:26 PM
bejoykr bejoykr is offline
2001 Rodeo - Need Help Identifying Issue
Hi All,
I have a 01 Rodeo with 75K. Recently it started throwing codes 171 - 175. This only happened when I take it on long drives. Once its been running long, it would kind of hesitate and then the codes will popup. So changed the O2 sensors. It also threw a 300 and based on that changed the sparkplugs(NGK).
Last week on another long drive, with AC on, it started hesitating with flashing CEL and then completely stopped. Giving it gas would do nothing and had to get it towed. After it cooled off, it is working again. Took to the dealer and they can't find anything wrong.
BTW in the mornings, it wont start on the first one or two cranks and then does a little bit of hesitation for the first couple minutes of driving.
Any idea what this could be?
Old 08-17-2011, 11:14 PM
Re: 2001 Rodeo - Need Help Identifying Issue
Any help?
Old 08-18-2011, 10:20 PM
Cat Fuzz Cat Fuzz is offline
Don't shoot the messenger! I'm not sure why people instantly think o2 sensors when this code pops up. They are simply reporting what they see. You likely have a faulty MAF sensor or a vacuum leak somewhere.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 08-19-2011, 10:30 PM
amigo-2k amigo-2k is offline
Isuzu Guy
I would keep it simple and change out the fuel filter to start out with ...
Also it could be a bad intake manifold gasket .... super common issue ....
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-22-2011, 02:21 PM
Thanks...will start with fuel filter. The dealer said it could be the MAF, but not sure.
92 92 rodeo tranmission line? need help identifying specialed Rodeo | Passport | MU 4 07-05-2007 07:33 AM
Need help identifying a car TcarR F1 44 07-10-2004 07:45 AM
Need Help Identify Part sickhonda Accord/TSX/Accord Hybrid 5 07-16-2003 01:29 PM
need help identifying sensors teg2nd Engineering/ Technical 4 10-14-2002 06:08 PM
Need help identifying items. kris General Discussion 1 02-03-2002 12:58 PM
