Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 08-16-2011, 12:51 PM
kprince65 kprince65 is offline
1977 E350 carburetor problems
I have a 77 E350 motorhome with a 460 and am having fuel problems. The carburetor is an Edelbrock 750cfm which is new and I have replaced the tank switching solenoid. My problem is that sometimes it acts as if it us running out of fuel, going up a hill sometimes it will start backfiring, if you let off the throttle it gets a little better. I have replaced the fuel filter as well and checked the fuel pump and it seems fine, no fuel coming out of weep hole. Is this a sign of vapor locking? Please help as I am at wits end with this vehicle . Thanks
Old 01-26-2015, 08:31 PM
dprice55 dprice55 is offline
Smile Re: 1977 E350 carburetor problems
Sometimes vacuum advance moving stator wires in distributor can cause intermittent open, when you let off wires move back to close the circuit. Worth a look. Continuity light and vacuum pump required for diagnosis. I see this is old post but might help someone!
Old 03-27-2015, 02:58 PM
AllenAtLarge AllenAtLarge is offline
Don't know if you found your problem but I have a 78 E350 that was having the same problem. It ended up being the fuel line itself had a hole in it that you couldn't see unless you were running. The lower the gas got the harder it would be for the pump to suck gas and would act like it was running out of fuel.
Old 03-29-2015, 09:46 AM
DeltaP DeltaP is offline
Or charcoal in a main jet caused by flooding the vapor cannister. We used to put a cotton ball in the hose from cannister to carb. Solved the problem.
2001 E350 Sputtering problem j.rudder E Series 0 06-18-2007 12:17 PM
1999 E350 Transmission Problems Wayne6873 E Series 0 03-19-2007 05:52 PM
carburetor problems... edothas Engineering/ Technical 0 11-13-2003 11:03 PM
1989 Honda Prelude Dual Carburetor Problem Jkendall Prelude 0 07-20-2003 09:26 AM
