Old 08-15-2011, 09:08 PM
spica4038 spica4038 is offline
2002 GP AC intermitant problem
2002 GP SE AC fails some times. When it works, everything works fine. When it fails, AC does not come on under any circumstances. Max AC with fan set at 1-5, no AC light. Other vent settings with fan set at 1-5, no AC light. Light does not come on when I press the AC button. I believe that the fan on/off controls the AC. Fan does not come on at all when failure occurs.
Old 08-15-2011, 09:39 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 2002 GP AC intermitant problem
Your fan switch is the "master" on -off switch for the a/c as well-- since there are speeds 1-4 and "off" on that switch.....the green light going off is your primary clue--it indicates a failure to make continuous contact with the brushes that control the a/c circuit
So I high suspect a faulty fan switch- take control head out, take fan switch off of the control head and look at fan switch contacts-that control the a/c make sure they are not gummed up with hardened grease...bend them so they make better contact...see if that helps.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
spica4038 (08-16-2011)
Old 08-16-2011, 10:27 AM
Thanks for the suggestion. I pulled off the switch knob but I don't see the contacts. Do I need to remove the dash panel to access? OK since I also need to remove the panel to replace the backlight for the clock/radio.
Old 08-17-2011, 10:16 AM
Anyone have a picture of the switch (inside)?
Old 08-20-2011, 02:28 PM
Tech II Tech II is offline
Really need a TECh II scanner to trouble shoot this......first, you need to see if there is an A/C "request".....then you need to read the data from the pressure sensor......then you need to see if the PCM is grounding or attempting to ground the clutch relay.....
Intermitent starting problems Driver2001 Grand Marquis 3 10-25-2010 05:56 PM
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
1997 Ford Ranger Intermitment problems bmm95 Ranger | Courier 4 09-10-2005 10:53 PM
'95 Intermitent Problem DeathFromAbove Contour 0 03-03-2005 12:09 PM
