Old 08-15-2011, 01:12 PM
Colt Hero Colt Hero is offline
'97 Taurus GL Wagon 197k: Driving itself, stalling/high idle, tach bouncing
Some of this stuff has been going on for some time now (several months ... maybe even a year).
1.) Driving Itself:
Car seems to drive itself on my way home from work which is a long, flat road in the 45-55 mph speed range. Once I get into this range, I can take my foot off the gas pedal and the car pretty much maintains speed until I get to an upgrade. I've even noticed times when I'm not pressing the pedal but the car is slightly speeding up to the point where I have to keep tapping the brake to keep from getting too close to the car in front of me.
2.) Stalling/High Idle:
Sometimes when I come to a less than smooth stop at a light - say, a yellow light that quickly turns red and I have to stop quicker than I'd want, the car will stall out. This has only happened a couple of times in the last 6 months, but it had never done this at all up to this point, so it's a new phenomena. Otherwise, the idle is usually at 600 rpm (except recently I've been seeing high idles of 2000 rpm every so often, which is really weird!!). Also, it seems like if I park the car on an incline, the engine will turn over many more times trying to "catch" and start - and the whole start-up sequence just feels weak - like it's not getting enough gas.
3.) Tach Bouncing:
This one's got me the most concerned because I think it's the most serious (and potentially the most costly to fix). I completely transfused the tranny fluid a few months ago as a possible solution, by the way, so the fluid (Dexron Mercon IV) is fresh. At about 1500 rpm on the tach, the tach sometimes starts bouncing up and down on the scale and I can feel a metallic engagement/disengagement cycle. If I get above or below this area on the tach, however, no problem. Also, taking off from a standstill -even though I accelerate very slowly and smoothly because I KNOW the tranny is "soft" and will 'slip and slap' if I don't - I'm recently starting to feel a very very brief grinding-like slippage feeling that does not hinder acceleration much at all, but feels very unsettling. This is a new feeling and it only happens every now and then (so far).
You're gonna say the tranny's on its way out, right?
Old 08-20-2011, 09:24 PM
plymouthsrock plymouthsrock is offline
Re: '97 Taurus GL Wagon 197k: Driving itself, stalling/high idle, tach bouncing
Check for stored trouble codes. I would guess 1 & 2 are related, and probably to a dirty throttle housing and/or IdleAirControl valve, assuming there are no DTCs for anything else. A check of the ThrottlePositionSensor might give you a clue to the first part of (3).
Old 08-21-2011, 10:10 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
I don't think the transmission is a likely culprit for what you discuss above. I'd start out like plymouthsrock suggests, cleaning the throttle body, remove the Idle Air Control (IAC), clean it and its passages (I prefer STP Throttle Body cleaner), and make sure the throttle cable is not binding.
For the bouncing tachometer, that used to be a pretty characteristic sign of a bad ignition control module. I don't think your '97 uses that, but if it has a distributor, it may also have an ignition control module. If it is a coil pack system, them it's probably more likely the Camshaft Position (CMP) sensor. The metallic noise you are hearing is probably the Camshaft Synchronizer. There have been several posts/threads on this forum about the synchronizer. Try a search for keyword "synchronizer" and see if they match your symptoms.
-Rod
94 cutlass 3.1 high idle gc9150 Cutlass Series 0 06-21-2011 05:51 PM
1997 Taurus wagon -alternator? Greeneyes_2006 Taurus | Taurus Wagon 6 04-12-2010 01:41 PM
'97 Taurus wagon...Stalls, no speedo, shift badly me262 Taurus | Taurus Wagon 2 02-23-2010 08:01 PM
'97 Taurus Wagon GL (3.0): Power Window Just Quit Colt Hero Taurus | Taurus Wagon 9 05-26-2007 08:53 PM
unstable idle, tach bounces around! MBCaprice SC/SL/SW 3 10-08-2004 10:56 AM
