Old 08-15-2011, 08:01 AM
JustShar JustShar is offline
Cool 2000 grand caravan won't start
2000 Grand caravan wont start turns over no spark
2000 grand caravan 3.3 v 6 flex a604 transmission. Just replaced front transmission seal. After getting trans back in the motor turns over but there is no spark. Wondering what the most likely cause is? Thinking throttle position sensor..... Any directions on how to test different items would be much appreciated. Limited experience with all the modern electronics. Thanks in advance!
Old 08-15-2011, 02:55 PM
Alphabravo Alphabravo is offline
Re: 2000 grand caravan won't start
I'd look around the area where you worked. I would look at the crank position sensor and the wiring that connects to it.
The Following User Says Thank You to Alphabravo For This Useful Post:
JustShar (08-15-2011)
Old 08-15-2011, 04:51 PM
jpb53 jpb53 is offline
If you did not remove the crank sensor before you r&r ed the trans you probably bumped it and damaged it.
The Following User Says Thank You to jpb53 For This Useful Post:
Old 08-15-2011, 09:19 PM
Lol we us we unplugged it and plugged it back in and it worked ty ty
Old 08-16-2011, 05:13 PM
Glad it worked! Thank you for posting the solution.
Grand Caravan won't start sometimes draksig Caravan | Voyager 24 08-12-2008 08:41 PM
94 grand caravan won't start- fuel pump? highmileage Caravan | Voyager 8 12-03-2005 07:13 PM
2000 grand caravan wont start handymom Caravan | Voyager 0 08-06-2004 01:25 PM
2000 Grand Am won't start rwrighter Grand AM 0 07-28-2004 10:51 PM
