Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 08-14-2011, 10:48 PM
Stock00ClipseGT's Avatar
Stock00ClipseGT Stock00ClipseGT is offline
2000 Eclipse GT - Problems
Bought it in 2009. About 115k miles.
Body = Excellent/near pristine condition.
Work we have had to do on the car: New clutch, new alternator, new struts, new turn signal rod.
Car currently grinds when attempting to go into reverse. This was a small problem before I had the clutch replaced and the person who replaced the clutch did not mention it. The problem has now gotten worse. What is wrong with the car?
There is also a sound I am hearing coming from the front left side of the car which only occurrs when the car is in gear.
Suggestions/advice?
Old 08-14-2011, 11:06 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: 2000 Eclipse GT - Problems
Grinding only going into reverse leads me to believe that the syncro's for reverse are bad and that would mean it's a time for a rebuild. Or you could just live with the problem till the tranny finally breaks. I had a 2000 Cougar (same car as the Eclipse) and it did the same thing. Drove it for about 2 years with the grinding happening till the tranny finally broke.
As for the sound coming fron the front left of the car when the car is in gear...you didn't mention if the car is in gear AND stationary or if the car is in gear AND moving......so which is it?
Old 08-15-2011, 01:59 PM
Thanks Tony. The sound coming from the left front end is most noticeable when I'm in gears 1-3.
With the grinding when trying to go into reverse, does the fact that I just had the clutch replaced matter?
Old 11-25-2011, 02:02 AM
stevo2412 stevo2412 is offline
i have the same car just rs and manual and i have like almost the same problems except when in reverse my car just vibrates a little strange no grinding. and my front right tire makes a weird sound only when i turn right. i have no idea what it is im just now looking into it.
Old 11-25-2011, 02:29 AM
Yeah it kinda sucks. Mine is an internal transmission problem so I'm basically screwed. Trying to get around $3,000 for it but doubt that will happen.
96 Eclipse Rs Non-turbo Vacuum problem. donidavis Eclipse Problem Diagnosis 27 08-29-2010 09:07 PM
idel adjustment problem 2000 eclipse benjamingears Eclipse Problem Diagnosis 0 01-24-2006 09:53 PM
2000 Civic V.S. 2000 Eclipse Mumm '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 08-22-2004 07:54 PM
97 eclipse engine swap 2000 eclipse mikep1117 Eclipse 2000+ 6 05-09-2004 02:27 AM
2000+ eclipse forum: "mr-s vs. eclipse gts??? who'd win?" Fenixfire077 MR2/MR-S 3 04-28-2004 06:24 AM
