Old 08-14-2011, 03:02 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
popping noise
hi guys, my cars been making this noise for the last 2 years , but it has gotten especially worse this summer. when im driving over a bump ill hear this noise that sounds like the battery bouncing up a few inches the dropping back down. (ive confirmed thats not the case) also sometimes when i go to make sharp turns, like in a parking lot, ill hear a popping noise. this noise is much worse and happens nearly every time i go in reverse while turning sharp, like when backing into a parking spot. and is even worse when i back into my parking spot in front of my apartment, which is at a downward angle (so im backing up and turning, up a hill) im guessing control arms but before i shell out $100 (they have gone down in price considerably at rockauto) i just wanted to get everyones opinions.
thanks in advance!
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 08-14-2011, 05:56 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
Re: popping noise
ball joint or wheel bearing maybe
2000 Grand Prix GTP Daytona: 4k original miles
1997 Pontiac Grand Prix GTP bought with 68k, sold with 112,000, and i loved every mile
2011 Subaru Legacy 2.5i (daily driver)
1973 MGB
Old 08-14-2011, 06:09 PM
Tech II Tech II is offline
Re: popping noise
Get the front end checked out.....
Old 08-15-2011, 07:52 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: popping noise
Depending on what the popping sounds like, maybe a bad CV joint, or lower control arm bushings. The other noise while going over bumps, I'd say that could be a bad tie rod, or ball joint.
Old 08-15-2011, 08:03 PM
rickisrad rickisrad is offline
Re: popping noise
definately sounds like a control arm issue or your intermediate steering shaft. did you check the round bushings? use a flash light and you should be able to see the hockey puck looking bushing. it should not rest against the frame or be seperated at any point.
btw GTX -look at my sig. it is a pre-production
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 08-16-2011, 03:44 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: popping noise
I agree with the others that the noise you're hearing is the "hockey puck" lower control arm bushing.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-16-2011, 09:18 PM
johngandersonjr johngandersonjr is offline
Re: popping noise
Also check the sway bar link. i don't know if this car has one but it is a real common item and cheap to fix!
if the bold snapped or rusted off that would make the noise going over bumps and turning.
Hoping someone could help with a Pop in my Tranny. Germ305 Explorer | Explorer Sport Trac 0 08-07-2010 09:14 PM
popping noise when I turn steering wheel... phughes Grand Cherokee | Grand Cherokee SRT8 3 08-01-2010 03:15 PM
do u ever hear a pop!! noise when... vtecntrldSI '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 03-01-2002 12:41 PM
popping noise on door close nldesai Maintenance 0 02-23-2002 12:38 PM
