I just recently purchased an 03 Trailblazer with the 4.2 L6. It has a bunch of miles (169,000) but was a one owner and was a steal for the price. It replaced an aging 1990 GMC Jimmy (K5 Blazer) with so much rust it got dangerous to drive. This is our third vehicle and basically takes me to work and back.
Anyway I have had a few problems including the need to replace the thermostat because of the low temperature code. The rear shocks were shot and the throttle body needed a good cleaning. Runs great now. Other items of concern are the front struts, the front stabilizer bushings, and possibly the front hubs. Apparently there is a stored code for a lost single on the front right speed sensor but no ABS or SES lights. So I am holding off on those for the moment. Without knowing much else about the history of this ride what else should I look out for? Finally I wanted to say thank you to everyone that has posted their results because they have been extremely helpful.
2011 Chevy Malibu 2012 Dodge Ram Crew Cab (Camper Puller) 2003 Trailblazer LS 4X4 1990 GMC Full Size Jimmy 4X4 RIP
Re: New to the Trailblazer
You maybe in for a shock change. Some stats and a pipe/housing that comes with it are high priced and take over several hrs to replace on Trail Blazer. Clear ABS code and see if it comes back. Look over belts and hoses and spark plugs and filters and brake pads. Transfer case fluid and transmission fluid should be serviced if not done. The coolant should be changed /flushed ever 3 years or 50K not the GM 5-7 year 150K to long service. Do you regular maintiance and drive it. Good Luck
| The Following User Says Thank You to MT-2500 For This Useful Post: | ||
taxman82 (08-14-2011)
If it's a 4X4, you can pretty much expect to have to replace/rebuild the actuator bolted to the side of the engine oil pan.
The gears and bearings inside are a known trouble spot. Initial symptoms are whine/growl especially when in 4 wheel drive; sometimes with much reduced whine/growl when in Automatic 4 wheel drive but not completely engaged. The typical "fix" is to buy a rebuilt unit, and simply switch the defective one for the rebuilt one. I think the replacement cost me about $425 two years ago; and I installed it myself. Prying the old one out of the oil pan is the worst part of the job. It's a loose "press fit", but the two aluminum parts corrode together and become a bitch to separate.
. . For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China. |
Thanks everyone. I have a few things left to do. Like Chevy 29 I have to do the front stabilizer ends. I have already cleaned the TB because it was stalling with the air on after I disconnected the battery. It was pretty nasty in there.
Thermostat was done Friday. God is that a pain.. Somebody at GM really screwed up that placement. Yuck.. Upcoming this weekend or next: 1) Front brakes including rotors. 2) Fuel Filter. 3) Front stabilizer ends. Overall for almost 170,000 miles now it runs really well. The motor is perfectly smooth and my wife likes it better than the 2011 Malibu we bought. Hum.. almost makes me wish we bought a newer one with less miles. Oh well see how far this takes me. Thanks for all the suggestions.
