Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-13-2011, 01:05 PM
badtransam86 badtransam86 is offline
1998 ford mustang 3.8 running problems
earlier this week about monday my car broke down that morning i got in it, it started right up and i moved it in front of my house to get some boxes out of the trunk later that day i got in it to go down the road tried to start it and it had flooded out and it wouldn't move so couple more tries it done the same thing and then it was dead all at once there was no fire at all so i got to troubleshooting the next day i poured gas directly into the throttle body and it starts for a couple of seconds then quits i kept doing this until it kept running on its own so finally i hooked everything back up got it and went up the road with it i got to run it for about 30 minutes with a slight hesitation and then it quit and never started back so i had a tester put on it at advance auto parts they told me it was the mass air flow sensor and it was running lean on number one cylinder which they said that it was caused over the maf sensor was down so i got it and put it on it fired back up and run good about half the night i tried it the next morning and it went back doing the same thing all over again even my window wouldn't roll up it would just click so i thought well maybe the spark plugs was out where it flooded out so i went and got some bosch platinum plugs and put in it and now after i done that my window rolls up and done good since then and now the car runs good until it warms and it starts hesitating and making like a gargle sound like it did before i have no idea what going on with it when the motor is cool it will run like a jet goin up the road and when the tempature guage gets up in the middle thats when it goes back down hill does anybody have any idea of what this sounds like or whats goin on with it
Old 08-13-2011, 01:13 PM
Re: 1998 ford mustang 3.8 running problems
and also i forgot to add that when the car is warmed up and quits i can turn the key off and back on and then it will take right on off
Old 08-14-2011, 01:25 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
3 things make a car run, fuel air and spark. Find out which one of those is not contributing and you found your starting point. Check fuel pressure first to rule out fuel pump/regulator issues.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 08-26-2011, 01:27 PM
figured out the problem with the car it was just water in the gas i poured seafoam in it, it made it run little bit better that day when it set overnight it was back to normal
3.8 head changes. help? thunderbirdcoupe89 Thunderbird 2 12-10-2009 11:43 AM
2011 Ford Mustang Specs Leaked (400hp!) iafb83 Automotive News Desk 1 09-11-2009 01:31 PM
1998 Ford Mustang GT Shifting Problems stowerh Mustang Problem Diagnosis 4 07-22-2009 10:15 AM
95 Mustang 3.8 V6 Running real rough all of a sudden. Dan Cook Mustang Problem Diagnosis 3 03-27-2008 08:07 PM
1990 Cougar V6 3.8 running problem SnipesXxX Cougar 1 11-12-2006 08:34 PM
