Go Back   Automotive Forums Car Chat > Cadillac > Cadillac Classics
Old 08-13-2011, 06:12 AM
diesel1962 diesel1962 is offline
78' Eldroado Hub Caps
Dumb question.. Removed hubcaps from my car,and am having hard time installing them!!. How do I do this without denting them up?.I already bent the tab's on the cap's hoping that would cure the problem,but that did not work.Any ideas??.Thanks....Diesel1962
Old 08-13-2011, 04:16 PM
maxwedge maxwedge is offline
A990 racer
Re: 78' Eldroado Hub Caps
Can't get them on working around the outer edges, never had this happen.
Old 08-13-2011, 08:16 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Did you give them a bang around the edges with the palm of your hand?
Old 08-14-2011, 06:59 AM
Thank's for the reply.Yes I did and I used a soft rubber mallet.These hubcaps have not been removed in a long time.It don't appear that they are already bent in anyway.Had to remove wheel to inspect RH axle shaft(have to rebuild the darn shaft!!).Should I try to bend tabs on the hubcap some more? Would hate to lose one going down the freeway.Thank's.. Diesel1962.......
Old 08-14-2011, 02:58 PM
A990 racer
No need to bend the tabs if you did not damage them coming off.
Old 08-14-2011, 09:43 PM
Thanks..Got hub caps back in the car with no damage to them.Forgot what a pain they can be at times as I have not owned a car that had full sized caps on the wheels!! Diesel1962
Old 08-15-2011, 01:41 AM
Moppie's Avatar
Master Connector
I'm trying to think the last time I removed an old style hub cap, everything I've owned since my first car has had mags on it.
78' Eldroado Axle shafts diesel1962 Cadillac Classics 2 08-14-2011 09:47 PM
Got a new set of Honda Hub Caps to cover my ugly steelies. l2ice rocketz '88 - '91 Civic | CRX | Wagon | Shuttlee 24 04-28-2003 06:30 PM
Honda Hub Caps OldSchoolHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 7 08-25-2002 11:53 AM
