Old 08-12-2011, 10:56 PM
walt03 walt03 is offline
97 Buick PA ultra AC problems
I installed a rebuilt supercharger and disconnected the battery apparently with the ac on.
After the supercharger was replaced, I connected everything and when I started the car the AC contols don't work.
I have to turn it on manually even though I turned it to AUTO. It only works in the defrost and floor position even though I manually move the mode swith through all positions, mid, mid-floor, floor, windshield-floor. I have to manually move the fan speed also.
I then turned the AC controls to off, disconnected the positive side of the batteryand let it set awhile. I reconnected everything, turned the key to on for awhile and started the car. I then heard actuators working when I turned the AC controls to on but the AC still works but still doesn't respond to the AC controls.
The AC worked well in all positions B4 I disconnected the battery while in the On position. to replace the supercharger.
I'm really frustrated and need some expert advice.
Thx
Old 08-13-2011, 09:31 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 97 Buick PA ultra AC problems
Not real sure on this one. You can try disconnecting both battery cables and touch both cable ends to each other, hold them togther for about 30 sec. this will completely drain all capacitors in the vehicle and maybe "reset" the a/c module. I've had this work on some oddball stuff before. I have also read on some other posts to turn the ignition key to the on/run position for 3 minuites (car not running). This allows the actuators to relearn their positions. Good luck!
The Following User Says Thank You to gmtech1 For This Useful Post:
walt03 (08-15-2011)
Old 08-13-2011, 11:42 AM
I'll give it a try later today, thanks!
Well I made some progress.
I disconnected both battery terminals and connected the with a battery cable for 15 minutes.
After re-connecting them, I had the AC unit OFF and put my ignition key into the run position for 15 minutes. When I started the car, I hit AUTO on th AC main control and I started ti get cold air from the main dashboard vents, all 4 of them. However, this last for two minutes and without doing anything, the auto went off and the cold air started back through the windshield and floor vent.
A good start but what should I do now? Disconnect all the actuators behind the dash board panels while disconnecting again both battery terminals and starting over again?
What should I do next?
Old 08-15-2011, 09:19 AM
Old 08-15-2011, 10:50 AM
brcidd's Avatar
brcidd brcidd is offline
You obviously have a vacuum leak- underhood from when you disturbed the vacuum source when you replaced the supercharger- Your issue is NOT electronic- it is vacuum....look for cracked/broken deteriated vacuum hose connections- trace it back from vacuum reservoir on firewall to engine intake source....replace hoses, lines as necessary.
Whenever there is not enough vacuum supplied to climate controller- the spring loaded air mode doors default to defrost for safety reasons...this is your first clue. Also a second clue is that the air flow will divert to floor and defrost while under massive acceleration maneuvers---because there is less vacuum available from your engine under these conditions.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
walt03 (08-15-2011)
Old 08-15-2011, 10:56 AM
688i 688i is offline
I had this problem once and it was due to disconnecting the battery by taking off the positive cable first instead of the ground cable first, as is the proper way to do it. If you do it backwards the right side actuator arm that directs flow to the proper places breaks and you end up with A/C like you have it. There are some good posts and pics on how to replace the actuator in the database if you search for them. Good luck. I have had numerous small problems like this with my 96 PA since I bought it in 2004. If it wasn't for this board it would have cost me a fortune to have them repaired. I like the car but it sure has a lot of high dollar electronic gadgets that wear out or fail sooner or easier than I think they should. I also forgot about the vacuum line problem I had too that is similar to this. The plug behind the glove box that all the vacuum hoses go into will become soft and collapse and cause flow direction problems. There are also some good threads about the repair options for this poor design also you can find by doing a search of this forum.
The Following User Says Thank You to 688i For This Useful Post:
walt03 (08-15-2011)
Old 08-15-2011, 10:38 PM
I used some propane torch gas to go around all the hoses and fittings while the motor was running and the idle didn't increase. I guess I didn't have a leak with hoses in the engine compartment after the supercharger job,
I'll need to find where the vacuum line goes inside the dash and check it out that way.
Thanks,
Old 08-16-2011, 09:53 PM
Tonite, I replaced each vacuum hose I could see on the engine but to NO avail. The AC still blow on the windshield and floor no matter what setting you move to. I want under the car, firewal area and didn't see where any vacuum on the 97 PA goes into the cabin,
On another post their was a vacuum block behind the glove box,, Does anyone know it it's there on the 97 PA?
Thanks for all the input as I'm trying everything.
Old 08-17-2011, 05:20 PM
temperingloser temperingloser is offline
in the bottom right casing below the glove box there is a place where all of the vacuum lines connect to a plastic piece which has rubber that collaspes after some some time you need to bypass the plastic piece where they all connect the same thing happened to my 96. search the forums there are more articles like this and some helpful pictures
The Following User Says Thank You to temperingloser For This Useful Post:
walt03 (08-18-2011)
Old 08-17-2011, 05:24 PM
one more thing the vacuum line going into the cabin is located on the passenger side towards the top
walt03 (08-18-2011)
Old 08-17-2011, 11:10 PM
I went to the Buick dealer Parts department and looked at a microfiche of the AC controls.
I talked to a mechanic that came in asking for the location of the vacuum manifold beheind the glove box. He spent some time with me and when we looked at the fiche, there was no vacuum lines there. He told me to hook up a scanner and read the body module codes as everything on this model is electronic. ????
From the firewall, I don't see any lines going thru the firewall,
Maybe on the 97PA there's a vacuum resivor around the front wheel ?
Any more tips from the more experienced?
Thanks
Old 08-18-2011, 01:08 AM
enslow enslow is offline
Thanks
This article may help you. The exact location of the programmer may be different on the Park Ave to what's pictured in the article, but the basics are the same.
http://www.imcool.com/articles/airco...acuum_line.htm
The Following User Says Thank You to enslow For This Useful Post:
walt03 (08-18-2011)
Old 08-18-2011, 09:03 PM
Is it in the 1" thick bundle of wires etc. going through the firewall behind the AC accumulator?
I don't see any separate vacuum line?
Thanks
Old 08-18-2011, 11:00 PM
Check out this link for a fix to your possible vacuum connector issuehttp://www.imcool.com/articles/airco...acuum_line.php
walt03 (08-19-2011)
Old 08-19-2011, 12:05 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Would this be the link?
The Following User Says Thank You to HotZ28 For This Useful Post:
walt03 (08-19-2011)
2003 Buick Ultra EGR ellis479 Park Avenue 4 04-23-2009 05:53 AM
93 Buick Ultra dash trim mksimmonds Park Avenue 2 05-03-2008 12:23 AM
1991 Buick Park Avenue Ultra Problems sarotara Park Avenue 6 11-27-2005 10:08 PM
Blower on 97 Buick Ultra Ftrev Park Avenue 5 02-23-2005 05:18 PM
1999 Buick Ultra Low Oil Pressure Problem Greichen Park Avenue 8 02-14-2005 10:10 AM
