Go Back   Automotive Forums Car Chat > Pontiac > G5
Old 08-12-2011, 05:48 PM
voltmaster63 voltmaster63 is offline
G5 automatic transmissiom problem
I have a 2007 G5 that will only shift 1 time. The car was fine when parked. Any help with this problem would be appreciated. Thanks in advanced Jeff.
Old 08-13-2011, 11:32 AM
Tech II Tech II is offline
Re: G5 automatic transmissiom problem
Check fluid level and condition?
Check for transmision codes?
Old 08-15-2011, 10:48 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
Jeff,
Have you brought this to attention of your local dealer? I can also look into this for you with your VIN. Please feel free to contact me via private message. Thank you.
Tricia, GM Customer Service.
Old 08-15-2011, 01:20 PM
procaddytech procaddytech is offline
What do you mean by shift once? Can you take off in one gear, drive, then the car will shift once and you can keep driving with only the 2 gears or does it try to shift a third time but rev like it is in neutral? Does reverse work? Or does the car engage into gear once but will not move? How about when you manually shift from L to D? After checking the fluid and possible codes, the road test is the most important thing to figure out excatly what gears you have and in what ranges (shifter position).
98 4.6 automatic squeal problem and window problem Turbokid15 Mustang Problem Diagnosis 1 12-16-2007 07:10 PM
Transmissiom problem 96 suburban Steve L Suburban 5 04-04-2006 03:33 PM
Automatic transmissiom stuck in second gear crbartos C/K 12 11-08-2005 08:15 AM
93 Escort 1.9L Automatic, acceleration problems/ some solutions for common problems. jon_public Escort 1 03-31-2004 03:49 PM
Signal light problem and automatic lock problem crackur Grand AM 0 02-05-2004 08:25 PM
