Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 08-12-2011, 01:27 PM
delicatedelinquent delicatedelinquent is offline
Rear wheel bearings- how to tell which side is going?
Hi I know i have a bad rear bearing but i do not know how to tell which side it is on. Anyone have any ideas so i can isolate it?
Old 08-12-2011, 01:52 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Rear wheel bearings- how to tell which side is going?
First check for play in the bearing, top to bottom movement with the wheel on. You can also slowly rotate the wheels, leaving your hands on the tire to feel for any roughness/griniding. Try driving with a passenger in the back and see if they can tell which side the noise is coming from.
Old 08-17-2011, 10:55 AM
denisond3 denisond3 is offline
My technique is to jack up the car so both rear wheels are off the ground. I take a 3 foot wooden dowel 1/4 diameter, and hold one end onto the back of the hub where the bearing is located. The outer end of the stick I push against the small flap of skin at the front side of my ear. Then have someone spin the wheel as fast as they can by hand. The bad bearing will usually make more noise than the good side. They sell mechanics 'stethoscopes' for this purpose too.
One some cars, if the bearing is making enough noise, you could drive along beside a big brick wall (like the back side of the Walmart sized stores), with the windows down. Do it in both directions to see if the noise is more noticealbe on one side versus the other; the brick wall will reflect sounds pretty well.
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:38 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:37 AM
88Astro Rear Wheel bearing, how 2 pull axles? orvillespooner M Bodies 1 12-04-2006 07:40 PM
99 Blazer - How do you change the rear wheel bearings? apacifico1968 Blazer 4 02-11-2006 01:04 PM
