Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 08-12-2011, 12:48 PM
TLM17 TLM17 is offline
Question Heater/AC selector knob help!
We have a 1998 Venture van and the knob that controls the speed of the air on the dash!It only works on the 4th speed all of the others have either burnt out or just doesn't work! Can anyone give suggestions or remedies! Thanks in advance!
Old 08-12-2011, 04:26 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Heater/AC selector knob help!
Place ignition switch in run, blower on low setting. Backprobe terminal B of the blower resistor (yellow wire) to ground with a test light. The resistor is what the fan plugs into, lower right under dash, it has two connectors going to it. If the test lamp lights up, replace the resistor. If it does not light up, replaced the control head. You know the fan is ok.
infamous speed selector issue surrender Impala | Impala SS 4 01-11-2011 02:20 PM
No heat - help!!! aletha Taurus | Taurus Wagon 17 12-13-2010 02:57 PM
Heater knob bulb replacement - 93 geschaef Camry/Camry Hybrid/Vista 2 02-16-2010 01:54 PM
intermittent ac/heat blower '00 e320 tpking E-Class 1 07-12-2009 10:51 PM
No Light on 4Wheel Drive Selector Knob sdub TrailBlazer | Trailblazer EXT 5 03-19-2004 01:47 PM
