Old 08-12-2011, 09:54 AM
northerncountryboy northerncountryboy is offline
Angry Tail light issue
I have a 87 f150 and i replaced the headlight switch and connector now here is the problem, i pull out the headlight switch i only have headlights and no tail lights if i push the switch in just alittle bit the i get tailights but they are dim, after about a minute of driving the lights start flashing and the truck starts jerking any suggestions???? is it a broken ground or a short in the harness??
Old 09-04-2011, 07:31 PM
chamblizi chamblizi is offline
Re: Tail light issue
you have a ether a rusted, rotten or a nawed threw wire ...
broken wires can do amazing damage i have a friend with no tail lights but he takes shitty care of his van and does not change anything and he blames ford for his 87 econoline breaking down
there should be a device that detects wire shortages check with you local best buy or autozone for the name of the device
The Following User Says Thank You to chamblizi For This Useful Post:
northerncountryboy (09-10-2011)
Old 09-10-2011, 08:50 AM
OK i figured out the proble there was a wire pinched in between the rear taillight causing it to short out. fixed wire and works fine.
Old 09-11-2011, 01:47 PM
good sorry i replied so late
Tail lights not working when not in use? duhlikemanda General Discussion 2 02-28-2009 05:38 PM
Tail light Issues/Int Light Issues losttime Grand AM 6 01-14-2008 07:40 PM
Headlight/tail light issue gmb0623 Rodeo | Passport | MU 5 09-13-2005 01:54 PM
simple tail light issue? eclipse525 '94 - '01 1 06-18-2004 01:36 PM
92' Tail light issue deathscythe_xx Celica 2 03-06-2004 12:33 AM
