Old 08-10-2011, 02:23 PM
Talcan Talcan is offline
Send a message via MSN to Talcan
Exclamation P/S bypass?
Anyone know of any powersteering by pass pulleys or maybe shorter belts that i could use on my 99 GA 3.4 v6? my P/s is compleatly shot and i really do not want to pas up the cash to replace the pump. if anyone has any ideas let me know.
Old 08-10-2011, 03:59 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: P/S bypass?
Thats a lot of car to try driving with out power steering.
Have looked at getting another pump from wrecker and fitting it yourself?
Old 08-10-2011, 07:11 PM
thephantom1492 thephantom1492 is offline
Re: P/S bypass?
I wouln't recommand to bypass it. The power steering is required for proper driving. Yes, some car do not have P/S but the steering is made in consequence. Turning the wheel of a P/S without P/S is really harder, and could, in some case, be dangerously hard. Also, since it may be considered as part of the safety system, it could also be illegal to drive with the P/S bypassed.
I would go to a junkyard and buy a pump there, it shouln't be that expensive.
Old 08-30-2011, 05:50 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: P/S bypass?
I have driven one of these for about a yr w/o power steering.
It'll give you muscles in places didnt know you could get!
Dangerous too if you cant manhandle the wheel - lookout!
The worst part is when you have to stop and turn, or parking.
Plus it wore out a brand new set of tie rod end$, both end$!
Depending on whats wrong with the pump its not that expense.
Just a PITA to remove/replace.
Anyway if you need some info on how to remove this here is a link.
Power Steering Pump Removal
1999 Grand Am SS 3.4 OHV
The Following User Says Thank You to xeroinfinity For This Useful Post:
Moppie (08-30-2011)
Old 08-31-2011, 07:46 AM
Tech II Tech II is offline
Re: P/S bypass?
Is it the pump or the rack?
If pump, they are easy to replace.....disconnect lines to it, and 3 bolts....get one from the boneyard or buy one with pulley on it...
Important to fill the system and then bleed air out, by turning wheel fully side to side, with engine off, 10-20 times.....if you see air in the fluid......wait, and do several more turns.....then start...
Old 08-31-2011, 08:46 AM
Re: P/S bypass?
Not that easy Tech II! You have to remove the engine mount on the to get to all the bolts.
Old 08-31-2011, 05:01 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: P/S bypass?
With the proper tools, it can be done without removing mount. Remove cruise module and set aside, remove the one eng. mount bolt that sits in front of the rearmost p/s pump bolt, use a 1/4" drive 13mm wobbly socket, short extension and ratchet. This is how I do all of these. If these tools are not available, it is easiest to remove the mount. Make sure you have a floor jack with a piece of wood and support the engine under the oil pan. It will take a little wrestling to line the engine mount holes up when reinstalling. Good luck!
Old 08-31-2011, 07:45 PM
Thumbs up Re: P/S bypass?
You beat me to it, gmtech1
Old 08-31-2011, 10:44 PM
Re: P/S bypass?
i've done 1000's of these and you can get the bolts out without removing the mount but getting it back in, isnt always as easy.
And Ive seen to many to count w/o that 1 bolt, sometimes it'll wreck the pulley, thats always nice.
Old 09-01-2011, 08:04 PM
skeeter123 skeeter123 is offline
Re: P/S bypass?
Xero, I'm just curious, why would manhandling it without PS be harder on the tie rod ends than one-fingering it with the PS doing all the work?
Old 09-02-2011, 08:59 PM
Re: P/S bypass?
The suspension realy isnt made to operate that way.
And unless you are built like Arnold Schwarzenegger you end up yanking the wheel more than you normaly would to get it to turn.
That extra force/leverage just wore mine out, they were fairly new too. I guess the bad roads around here could have caused my tie rods to wear fast.
You can also prob damage the rack & pinion if driving it to long w/o PS, just gets gummy in there too!
EVAP Canister Issues/Possible bypass? sk8injon Engine and Transmission 1 07-25-2009 08:39 AM
bypass air conditioner skycor Cherokee 5 04-02-2009 08:07 PM
Passlock Bypass using PLJX Bypass module NJFrank Alero 1 11-27-2008 02:09 AM
egr valve bypass and evac system bypass rpage C/K 2 02-20-2004 10:09 AM
Bypass the Dealer schacker Dealer Experiences 2 08-03-2001 06:13 PM
