Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 08-10-2011, 10:48 AM
somick's Avatar
somick somick is offline
Do I need a scanner to replace brake fluid with ABS brakes?
This is actually the same question I posted in the Pilot section:
2005 Pilot with 70,000 miles.
When I replace brake fluid on a vehicles without ABS I use vacuum pump. I have done it many times without any problems. What is going to happen when/if I use the same pump on my son's Pilot? It does have ABS.
As far as I know Honda calls for a special scanner to bleed ABS brakes. I do not have one.
Thanks,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 08-10-2011, 04:13 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Do I need a scanner to replace brake fluid with ABS brakes?
not sure why you would need a scanner... unless there is a code you need to reset.
the why i bleed any car is empty the brake fluid res, fill with fresh fluid, then proceed to bleed the lines as normal, there by pulling the fresh fluid into the lines without introducing air into the system
Old 08-11-2011, 11:40 AM
somick's Avatar
That is how I usually do it.
I do not remember where, but in one of newer Honda's manuals I read that on Hondas's ABS system the bleeding is done with a scanner. I was really surprised. My 2010 Forester's FSM does not mention anything like that.
Thanks for reply,
Sam
Old 08-11-2011, 01:24 PM
somick's Avatar
And the answer is here:
http://www.stoptech.com/tech_info/wp_bleeding_abs.shtml
so I will do it the way I usually do and leave the ABS unit alone.
Sam
Front Brake pads replacement olopezm Grand Prix 8 11-02-2010 11:52 AM
2000 Ranger 4x4 trouble with ABS engaging tjohn2401 Ranger | Courier 1 01-15-2010 09:05 PM
Flushing Brake Fluid for 1994 Explorer with ABS Brakes mike422 Explorer | Explorer Sport Trac 1 05-27-2006 03:36 AM
Need Advice! Brake Fluid disappearing and Brakes have "dead" spots. Un-Mechanic Camry/Camry Hybrid/Vista 3 11-14-2005 03:58 PM
Replacing Standard Breaks with ABS Brakes? crazyitalian1988 Engineering/ Technical 27 01-18-2005 08:14 PM
Tags
bleeding , brakes , scanner
