Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 08-09-2011, 04:35 PM
JimRochester JimRochester is offline
Question Auto to 4 speed conversion
I really miss the four-speed of my previous Trans Ams. Other than the transmission, bell housing, clutch assembly and pedal assembly, anything else I would need? What's the best tranny for the 78 400?
1978 Trans Am Black T-tops 400
1999 Grand Am
1991 Firebird
Old 05-01-2012, 12:51 AM
tuske427 tuske427 is offline
Send a message via AIM to tuske427
Re: Auto to 4 speed conversion
Depending on the transmission you select you will most likely need a transmission mount, transmission cross member (modified or replaced) and possibly a modified or replaced driveshaft.
The transmission you select will depend on your budget and interests. Example: what is your intended purpose with the car? Are you trying to make your car look bone stock for 1978? Are you just driving it, or are you racing it?
Since you're looking at replacing the transmission I would recommend one with an overdrive. a T-56 6 speed transmission would be great. You'd have the benefit of a close ratio 4 speed with a double overdrive. The best of both worlds. these are plenty strong enough for your smog era 400 and are available. They're not the cheapest transmissions, but they are well worth the expense.
I hope this helps.
Long live the muscle car
86 f150 4 speed to 5 speed conversion ran981968 F Series 0 03-07-2010 08:11 PM
auto to 5 speed conversion. need help! savingazildjian5 Engine, Transmission and Drivetrain 3 07-06-2006 07:29 PM
1988 Dakota 4-speed auto to 3-speed conversion? HeadlessHorseman Dakota 0 02-25-2006 08:15 AM
4 to 5 speed conversion...... slammed89civic '88 - '91 Civic | CRX | Wagon | Shuttlee 14 07-05-2002 03:32 PM
auto-manual conversion? Shobo Engine 10 07-31-2001 05:00 PM
