Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 08-09-2011, 01:19 PM
HERM W's Avatar
HERM W HERM W is offline
Question 2000 lincoln continental starting issues....
Have a 2000 continental with extended crank. after 2-3 times of hittin the key it starts and runs. the car drives fine and have no issues. only on start up......i have replaced spark plugs fuel filter(which were needed) and fuel pump. put gauge on rail and at idle had 30psi. could i have a bad fuel pressure regulator. or does this veh have one. because there is not a return fuel line on this veh.....I need so help if anyone can give me some advise would be grately needed
Old 08-09-2011, 06:05 PM
ffreak's Avatar
ffreak ffreak is offline
Re: 2000 lincoln continental starting issues....
That's possible. What I would suggest is to check fuel pressure after it sets for a while and see if it bleeds off. And if so it should regain pressure as soon as ign. is turned on, before cranking. You shouldn't have to cycle the key any more times to regain pressure. I would be suspect of the regulator. Also you said you replaced the pump, did it have a check valve on the tube just above the pump on the sending unit assy? That could possibly be defective allowing pressure to bleed back off into the tank. Hope this helps. Good luck.
The Following 2 Users Say Thank You to ffreak For This Useful Post:
HERM W (08-09-2011), jon@af (08-09-2011)
starting issues with 89 buick KiloJKilo Century 1 08-09-2011 08:55 AM
1999 Lincoln Continental AC issue LincolnDriver Continental 1 07-22-2010 05:44 PM
1994 lincoln continental air strut hose cracked joemillar Continental 1 10-05-2009 10:29 PM
1998 lincoln continental electric problems linconman Continental 0 09-06-2009 11:43 AM
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 12:00 PM
