Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 08-09-2011, 11:30 AM
la1's Avatar
la1 la1 is offline
I/P Junction block HELP
seems my driver door actuator is not working. i think it might be the BCM tried a new actuator and it did not work. does the left side I/P Junction block C2 plug into C1, has a bolt in the middle of the block...going to do a continuity check from the bcm to the actuator connector...any info welcome
UPDATE Turns out there is an open going from the BCM to the actuator. In order to split the wiring in half to see where the open is , I tried to remove the I/P Junction block...it won't let go ...se the vid
http://www.youtube.com/watch?v=lpnHIoO7gbQ
UPDATE ....::::REPAIRED::::.... It was an open in a wire that went from the BCM to the actuator
Blend Door Actuator or Plugged Heater Core? CryptoJones Windstar 10 01-23-2011 10:33 PM
2000 Tahoe LT Fuel Pump, Cats and Door Actuator ediesel_b13 Tahoe 0 05-14-2010 10:36 AM
2003 Sable blend door actuator not working rdhaley Sable 1 03-02-2010 09:00 PM
04 yukon xl driver door instrument panel problems kminton85 Yukon 0 01-09-2010 10:57 PM
WTB: 2g Driver door handle & passenger PDL actuator vanilla gorilla Classifieds 10 10-04-2006 02:38 PM
