Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-09-2011, 09:44 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Valvetrain noise when engine is cold
I've got a '99 Teg LS auto trans with 67k miles. When I start it cold, there is some valvetrain clatter that quiets out after a few minutes. I'm thinking this is due to some sticking valve lifters but I don't know this engine very well.
Does the 18b engine have hydraulic lifters?
I've also seen on other forums that the noise could be due to a worn distributor bearing, but with this low miles I find it hard to believe. Or it could be both. Any info would be helpful to me. Thanks!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 08-25-2011, 09:56 AM
jdmccright's Avatar
The RustBuster
Re: Valvetrain noise when engine is cold
Update:
Well I added a pint of Marvel Mystery Oil to the oil and that did quiet it down some, but there is still some noise there. I think it needs a valve clearance adjustment.
I also cleaned the the spark plugs (looked good and properly gapped), the cap terminals and rotor blade. There's a bit of oil in the #2 spark plug tube, so looks like time to change the valve cover gasket & tube o-rings.
I did notice a little bit of play when I rotated the distributor by the rotor. I couldn't measure in degrees, but it moved maybe 1mm. Pulling/pushing on the distributor shaft showed no end-play. And the rotor is not loose on the distributor shaft. Shouldn't there be no play at all? What is normal?
Car runs good otherwise and gets the expected gas mileage, just louder than a Honda/Acura should be.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 09-12-2011, 11:53 AM
jdmccright's Avatar
The RustBuster
Update #2:
Just performed a valve lash adjustment and the noise has improved slightly but is still noisy when cold. Hope it isn't related to the bottom end....
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
whining noise when its cold outside mrsbb Durango 3 01-14-2009 10:26 AM
Noise When Starting Cold EGW9926 Colorado 1 08-06-2007 07:40 PM
97 JXI starts when engine cold but not when engine hot joshodonn Sebring | Sebring Coupe | Convertible 0 03-19-2005 07:20 PM
Noise when starting cold??? joe2106 Sierra 0 12-24-2004 07:10 AM
revolving noise when driving cold myse-r Sentra | 200SX (USDM FWD) 1 12-10-2003 01:43 PM
