Old 08-08-2011, 06:30 PM
mylows10's Avatar
mylows10 mylows10 is offline
95 s0 cpi tps sensor code
ok i got a 95 cpi s10 w/5 spd last week the tps went bad scanned the code it said low voltage to throttle positioning/pedal sensor.so i replaced the tps with ac delco sensor and truck still runs the same check engine light still on same code , wanted some input to see whats going on.
1995 s10 ls
2-12 ascendant mayhem woofers
dc 7.5
pioneer avhp 4100dvd
autotek eq
cdt 6.5 componants
scosche wires
batcap 4000
kinetik hc 2000
dc 175.4 4 channel amp
152.8 db certified loudest truck on the westcoast without a wall or blowthru and 2 batteries
Old 08-08-2011, 08:44 PM
mylows10's Avatar
Re: 95 s0 cpi tps sensor code
i think its the idle air control valve
1995 s10 ls
dc 7.5
autotek eq
cdt 6.5 componants
scosche wires
batcap 4000
kinetik hc 2000
Old 08-09-2011, 04:44 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Well what makes you think IAC?
Trying to out think a computers system can get a person into a lot of probelms.
Only proper testing will tell you the problem.
What was the code no. and what engine?
And what symtoms does it have?
What is it doing or not doing?
Was code cleared and sysyem checked for any codes coming back?
Codes do not say throw parts at it.
But check it out.
If you have a low voltage code first thing you should do is run a voltage check on it.
Always check input and out put voltage and ground and also sensor plug in and wiring.
MT
Old 08-09-2011, 11:32 AM
mylows10's Avatar
95 s10 v6 vortec cpi i believe the code was 1022 it said low voltage at throttle position /pedal sensor.cleared the code with scanner and it came right back.replaced tps still came back.idle was low about 5oo rms pulled out iac plunger was totally stuck tried cleaning with brake clean ,but still doesnt seem to work right.both sensors are oem original with 325k on them so i think its time to replace anyway,throttle did get stuck a couple of times lately too
1995 s10 ls
dc 7.5
autotek eq
cdt 6.5 componants
scosche wires
batcap 4000
kinetik hc 2000
Old 08-09-2011, 12:59 PM
MT-2500's Avatar
AF - Advisor
OBD11 code or engine code?
If it is a voltage code get out the volt meter and check the sensor voltage for up to specs.
You should have .85 volts or little less at closed throttle from sensor to computer and raise up even with nopdrop outs to 4.5 volts wide open throttle.
What are you voltage reading?
MT
Old 08-09-2011, 01:27 PM
mylows10's Avatar
4.89 at tps with key on and 11.08 at iac with key on with engine not running and it was p1022 i think
1995 s10 ls
dc 7.5
autotek eq
cdt 6.5 componants
scosche wires
batcap 4000
kinetik hc 2000
Old 08-09-2011, 03:41 PM
MT-2500's Avatar
AF - Advisor
That is the referance tps sensor feed voltage.
Check the other tps sensor wire to computer to get sensor voltage.
MT
Old 08-09-2011, 03:47 PM
MT-2500's Avatar
AF - Advisor
I do not Show a code 1022.
Recheck the codes no.
MT
Old 08-09-2011, 03:52 PM
mylows10's Avatar
i'll try to get the code again later and i'll check that other wire voltage
1995 s10 ls
dc 7.5
autotek eq
cdt 6.5 componants
scosche wires
batcap 4000
kinetik hc 2000
Old 08-09-2011, 03:57 PM
mylows10's Avatar
the blue wire is working like a ground , but i can find a break or anywhere where i could be grounding out if its not a ground
1995 s10 ls
dc 7.5
autotek eq
cdt 6.5 componants
scosche wires
batcap 4000
kinetik hc 2000
Old 08-09-2011, 04:08 PM
mylows10's Avatar
.03 at the sensor
1995 s10 ls
dc 7.5
autotek eq
cdt 6.5 componants
scosche wires
batcap 4000
kinetik hc 2000
Old 08-10-2011, 05:55 AM
MT-2500's Avatar
AF - Advisor
.03 at the sensor
.03 is to low.
Low enought to set low voltage code.
You should have 7 to 8.5 volts.
Always us a good digital volt meter.
Old type resister volt meters are no good for checking low computer voltage.
May even damage computer.
Did the voltage come up at wide open throttle?
At .03 voltstps out put to computer and 4.5-5 volts referance voltage and good ground and plugin wiring.
You have a bad TPS sensor or way out of adjustment or not hooked on the throttle linkage right.
If voltage does not swing up opening throttle it may no be installed right.
Remove it from throttle body and hook it up and take a screw driver and crank it and see if voltage swings up.
It should swing up to reference voltage 4.5 to 5 volts.
MT
Impossible TPS problem entrepa Sidekick 0 10-25-2010 07:25 PM
Coolant Temp Sensor and TPS sensor problems? DAVID A SMITH Grand Prix 1 06-01-2010 04:04 PM
1998 cADILLAC dEVILLE cONCOURS,LOCATION OF IAT SENSOR, and TPS Sensor jspeigne Deville 4 06-02-2008 03:14 PM
TPS and Knock Sensor Codes xjcamaro89 Silverado 27 04-21-2008 07:19 AM
TPS sensor bad! Throttle position sensor bratt Yukon 0 02-11-2008 05:23 PM
