Old 08-07-2011, 01:13 PM
McLin's Avatar
McLin McLin is offline
Need help I must replace the tensioner...
Hi,
we have an 3.8L 98 Lumina and must replace the L hose from LIM to tensioner and want to ask is this job done with just remove the tensioner or is there mor to remove? Did I need gaskets from tensioner to water pump? Thx.
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
Old 08-07-2011, 01:27 PM
danielsatur danielsatur is offline
Re: Need help I must replace the tensioner...
Don't forget to rent a surpentine belt tool @ the locai Auto parts store.
Old 08-07-2011, 01:35 PM
McLin's Avatar
Why this? I span the belt with a 15 nut and a wrench.
Best regards McLin.
My Lumina
Mileage:
Old 08-07-2011, 03:58 PM
It's designed to give more leverage, a belt change usually takes a few min.
Old 08-07-2011, 04:35 PM
procaddytech procaddytech is offline
To answer your question, you just need the coolant elbow and the new tensioner.
The Following User Says Thank You to procaddytech For This Useful Post:
McLin (08-07-2011)
Old 08-08-2011, 09:00 PM
If it's just the coolant elbow leaking, they canbe bought at the local Auto parts store.
Old 08-08-2011, 11:16 PM
McLin's Avatar
Did you have a part no or a name? I didn't find this hose alone...
Best regards McLin.
My Lumina
Mileage:
Old 08-09-2011, 09:08 AM
I think it's in the dorman section @ your local Auto parts store, it's a coolant heater elbow for around $2.00 / 1/2hr fix.
The tensioner still needs tobe removed, and all the broken pieces must be removed from both the intake & tensioner.
Old 08-11-2011, 05:59 AM
McLin's Avatar
Job is done, is very hard work, and I learned first make the hose in the tensioner and then in lim, not reverse...
Best regards McLin.
My Lumina
Mileage:
The Following User Says Thank You to McLin For This Useful Post:
danielsatur (08-12-2011)
Need help with installing tailgate tension bar Sen Sen Blazer 1 06-23-2006 11:49 AM
HELP! Need help on replacing a bulb.. soumienchiem Exterior | bodykits | Lighting 2 10-29-2004 06:50 PM
need help with replacement rims!! clean customs Diecast Car Modeling 2 03-31-2004 10:21 PM
Factory stereo stolen! - Need help for replacement slaeyer Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 02-17-2004 10:35 PM
