Could I get one million miles on my Camry?
So far my 02 Camry (2.4L engine) runs just as good as it did new, and I've barely had to do any maintainence on it other than oil changes and occasionally some new tires.. (I've had to replace a battery and get some brake pads replaced, but that's it).
I used Kendall oil (I've heard some engine oils are better or worse than others), I change it about every 3,500 miles, most of my driving is on the highway, and I don't hotrod the car. I just rolled over to 117,000 miles the other day (I'll probably be an old man when it hits a million at the rate I'm going). Do you think I could ever get one million plus miles on this car, or would it probably wear out before then? |
Re: Could I get one million miles on my Camry?
Make sure you change the transmission and power steering fluid periodically also. I suggest flushing the brake lines. Keep the antifreeze fresh. You will need Air/Fuel ratio sensors before long. The rear one may signal as a bad cat convertor, but most of the time, it's the air/fuel ratio sensor behind it. The ECM tests the cat convertor function through that sensor.
Good luck on your quest....
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
they are a known car to last a long time if maintained properly,but a million miles!!
you still got a long way to go not sure if the body & frame will make it.
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
Corrosion is your enemy...
Also plastic, rubber, seals, and gaskets will go bad in time.
I was hoping to get 1 million out of my '92. Had it up to 257k, then I wrecked it.
Hope you like driving it because it'll take decades to get to 1 million...as in another 59 years...if you drive 15k miles per year. Good luck!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
I can see it now... 999,999 miles. Watching the odometer to see it turn over, then CRASH!
take the car as far as you can go
There's a guy with an old Volvo that's approaching 3 million miles.
i wish there was a way to get these independetly verified
i have 175k on my 97 camry. it runs strong with no issues, only replaced the starter and thats it, obviously minor parts like pads and rotors have been replaced. 1 million miles is alot, shoot for like 300k or something for now.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Yes, Irv Gordon. And it's in great shape too.
That's my biggest question, does the odometer turn over to one million, or would it just stop? I emailed the Toyota website about this question once, and they said when it reaches the maximum number of miles, the odometer would just stop. They failed to mention what that number was... |
