Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-05-2011, 06:29 AM
sharkmonkey sharkmonkey is offline
2001 RAM 5.2 P0420 error code
Autozone ran the codes on my CEL and found P0420. They gave me four possibilities of what it could mean but I would like to narrow it down a little more if I can.
1. Catalyst efficiency low-bank 1, possible cause, defective Catalytic converter
2. Engine misfire or running condition
3. Large vacuum leak
4. Engine oil leakage into exhaust valve guide
These are four very different issues for this one code. How would I be able to narrow it down to the real cause?
Thanks, -mark
Mark "Sharky" Stover
73 Century Regal 455
05 Chrysler T&C
07 Dodge Ram SLT
11 GMC Yukon Denali XL
Old 08-05-2011, 12:03 PM
danielsatur danielsatur is offline
Re: 2001 RAM 5.2 P0420 error code
Profile the <make> <model> <year> , and mileage.
How doe's she run?
How's the mpg?
The down stream H02 sensor told the ecu, that the catalytic converter isn't doing its job on bank1.
A Test canbe done on your catalytic converter at any local muffler shop.
For DIY, do a Google ''Youtube auto catalytic converter test''
Old 08-05-2011, 12:51 PM
inafogg inafogg is offline
its also could be a bad/lazy 02 sensor
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 08-06-2011, 11:07 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
P0420 1/1 Catalytic Converter Efficiency Catalyst.
1/1 efficiency below required level.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 08-07-2011, 09:23 AM
tempfixit tempfixit is offline
I agree it could be the upstream 02 sensor, had the same code on my 98 windstar watched the operation of 02 sensor and found it to be lazy, replaced with new sensor and have not had code since. (Put on 5,000 miles since and the vehicle has 200k on it)
good luck
Old 08-08-2011, 10:29 AM
How doe's she run?
How's the mpg?
She runs really good as far as I can tell. I've only owned it for about a month. There's no missing or hesitation. I think the MPG is around 15 combined.
So is it most likely the upstream or the downstream sensor?
05 Chrysler T&C
07 Dodge Ram SLT
Old 08-10-2011, 06:32 PM
Hmmm, the CEL is no longer lit.
05 Chrysler T&C
07 Dodge Ram SLT
The Following User Says Thank You to sharkmonkey For This Useful Post:
danielsatur (08-10-2011)
Old 08-16-2011, 03:53 PM
angus10 angus10 is offline
Get an OEM sensor, not some junk from advance auto or the like. A Bosch is the worst choice.
98 Ram 1500 4x4
Flowmaster American Thunder W/super40
MPG of 93 Dakota 5.2 Magnum w/MSD Ignition tripod12133 Dakota 0 07-27-2010 10:21 PM
5.2, Very hot in cab, radiator cold. mrspooks Ram Pickup | Ram SRT10 0 08-15-2009 08:55 AM
2001 Saab 9-5 service soon and code 730 nero11 9-5 0 08-06-2009 08:43 PM
Gauges not working/No BUS 2001 Ram 5.2 challenger74 Ram Pickup | Ram SRT10 10 03-01-2005 08:03 PM
P0420 Error Code Cdawg786 Grand Cherokee | Grand Cherokee SRT8 0 01-08-2004 10:55 AM
