Old 08-04-2011, 09:05 AM
Dirtrunner Dirtrunner is offline
power steering whine
I have a 06 grand prix, super charge, 3.8. After 3 reman pumps it still whines, no air in system. Should I get new gm pump? Thanks
Old 08-04-2011, 09:39 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: power steering whine
Welcome to AF!!
A reman pump should be as good as a new one however there may be issues elsewhere. Are you certain that you don't have a belt tensioner pulley going bad? If you have checked all of the pulleys and they are good check the belt itself. It may not be properly aligned and is causing the whine. Finally, if you have checked all of these and the pump still whines I would try some power steering fluid additive like Lucas oil to see if that quiets the pump. If that doesn't work try a new pump but it is strange that three pumps would do the same thing.
Old 08-04-2011, 09:40 AM
danielsatur danielsatur is offline
Three pumps within how many miles?
Was the whole power steering system flushed?
Are you using power steering fluid, ATF, or syntheic ATF?
Old 08-04-2011, 09:48 AM
Godfathercac Godfathercac is offline
I have a grand prix GXP...
Had some whine and it ended up being the idler pullies...sure it's power steering?
chataboutcars
Old 08-04-2011, 10:02 AM
3 pumps within hours lol. Im using power steering fluid. The last pump I put on is the quite at idle and turning. When I rev it up it makes the whining noise, load noise.. Sounds like it's low on fluid, that noise, but it's not. Thanks
Old 08-05-2011, 08:47 AM
Doe's it whine when you turn the wheel to the left or right?
If you hear the whine with RPM's, it could be the idler pulley, or tensioner.
Power steering flush Windstar 98 - No place to work serge_saati Windstar 9 11-05-2015 08:02 PM
Problems with Acceleration and now Power Steering dbhynds '01-'05 Civic 5 01-06-2010 07:41 AM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 07:15 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
