Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-03-2011, 05:41 PM
cwhite57 cwhite57 is offline
88 acura integra won't start from time to time
I have an 88 acura integra and the problim is that once in a while it would not start after it had been running. If I let it sit for 5 min it would start. Now it is happening everyday. One time it will start great and run fine, but when I turn it off I don't know if it will start again. I checked the gas and it is getting gas and the pressure is fine, but when it last happened it would turn over but wouldn't start for the rest of the day, I checked and it had no spark. After I replaced the ignition control mod and rotor, it started on the second try but when i got to work and turned it off the same thing. I let it sit for a while (about 15 min) and it started. Like I said after it starts it runs great, lots of power, no missing or any thing.
Old 08-03-2011, 05:48 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: 88 acura integra won't start from time to time
Welcome to AF!
Can you give us some more info?
What engine is it running?
And by not start, do you mean the starter motor is working or not?
Old 08-03-2011, 05:52 PM
Originally Posted by Moppie View Post
Welcome to AF!
The starter is turning the motor over, just don't get spark from time to time. When it dose start it runs just fine.
Engine 1.6L fl 4cyl
Old 08-03-2011, 05:58 PM
Moppie's Avatar
Master Connector
How did you check the fuel pressure?
Old 08-03-2011, 06:01 PM
I had it in the shop and they tested it. But because it was running at the time they couldn't find a problim.
Old 08-03-2011, 06:03 PM
Moppie's Avatar
Master Connector
Ahh, you need to check it when it's not running.
Need to isolate the cause of the problem to fuel or ignition.
Old 08-03-2011, 06:10 PM
When it won't start I have no spark but i do had fuel.
Old 08-03-2011, 06:21 PM
Moppie's Avatar
Master Connector
Cool, did you test for spark at the coil, or just at the plugs?
Old 08-03-2011, 06:31 PM
At the plug. I heard if the coil is bad it would stop working all together, not from time to time or is this wrong.
Old 08-03-2011, 11:34 PM
Moppie's Avatar
Master Connector
Generally, but it could still be a bad coil.
Or, a bad earth, or bad connection to the coil, dizzy etc.
If you haven't replaced any of other ignition parts in the last 10,000kms, now would be a good time to do so.
Old 08-03-2011, 11:47 PM
I am going to pickup a voltage meter in the morning and check the voltage and resitance. I just need to find out the specks in the resitance. Will let you know what I find out tommorrow.
'88 acura legend won't start sometimes j_goerges Legend | RL 4 04-13-2009 09:38 AM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
94 Acura Integra HELM manual like new skola239 Classifieds 0 03-22-2009 09:56 AM
1991 Acura Integra RS - Starting Problem slot tech Engineering/ Technical 0 08-29-2003 05:08 PM
