View Poll Results: What should you do next if car wont start after changing cam sensor when it ran before the change?
Crank sensor change? 3 100.00%
Other sensor 0 0%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
Old 08-03-2011, 03:48 AM
trouble shooter trouble shooter is offline
Question 92 buick lesabre Trouble with car starting after cam...
Have 92 lesabre and had running problem at first but it did drive, then got a diagnostic. It read that the cam sensor needed replaced. So I got one and replace it. It started right up after i got it installed. The next day I went to fix the blinkers and tried to start car and now it wont start! It turns over like there no gas. It wont start running. So what should I do next considering I've done research and seen possibilities what the problems are: like crank sensor needs replaced and couple other things. NEED TO KNOW WHAT IT COULD BE WHY IT WONT START NOW? Please if anyone can give me a close idea of what it is so i wont put money into things I dont need.
Old 08-03-2011, 05:48 AM
procaddytech procaddytech is offline
Re: 92 buick lesabre Trouble with car starting after cam...
Did you replace the magnet in the cam sprocket or just the sensor? The magnets are known to fall out of the sprockets leaving nothing to trigger the sensor. Remove the sensor and rotate the engine until you can see a magnet or a missing magnet. May need a light and mirror.
If ok, go behind yourself and check everything you removed and replaced, disconnected etc. Not questioning your workmanship, it happens to us all. Something loose, partially connected, or pinched. Then to the diagnostics. Need fuel pressure readings, check for spark, injector pulse, try to start on carb cleaner.
Old 08-03-2011, 11:24 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Check fuse #6 in fuse panel under drivers side dash.
Old 08-03-2011, 06:40 PM
To the question on the fuse 6? Yes I checked that with other fuses and they are good. Thx for info
1997 Buick Lesabre randomly Dies (Electric) MikeTwoJay LeSabre 2 04-16-2009 08:37 AM
error or trouble codes 93 buick lesabre custom thecone_99 LeSabre 9 03-03-2009 06:49 AM
Problem with car starting after its warm up deb789 Grand AM 0 12-10-2005 04:44 AM
98 Buick Regel troubles with starting Mistyrose Regal 17 10-18-2005 02:05 PM
96 Buick LeSabre trouble starting alwerdt LeSabre 4 10-10-2005 04:13 PM
Tags
buicklesabre , cam , sensor] , startingproblemschanging , [=[92
