Old 08-02-2011, 02:19 PM
Alphabravo Alphabravo is offline
Question 2003 GC 3.3 169K Miles - P0420
Hi everyone. I just got a P0420 "Catalyst Efficiency Below Required Level" code today.
Now, if I understand correctly how this works, is that there is an 02 sensor before the cat and another one after and the PCM analyses the different readings between the two, and that's how it gets its "Catalyst Efficiency" reading, right?
I do not smell any anti-freeze and no oil is buring, so it is unlikely that the cat got contaminated. The O2 sensors have not been changed for at least 70K miles.
I'm leaning towards the O2 sensors first and if that doesn't work I'll change the cat.
Does anyone have any opinion/advice?
Old 08-02-2011, 07:08 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2003 GC 3.3 169K Miles - P0420
Zero experience on a P0420. Here's a little info:
http://dodgeforum.com/forum/dodge-ca...pert-help.html
http://www.obd-codes.com/p0420
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
Alphabravo (08-02-2011)
Old 08-02-2011, 08:01 PM
Thanks, RIP. Good info, as always. I have a feeling that the cat will need to be replaced.
Old 08-02-2011, 08:13 PM
tempfixit tempfixit is offline
Alphabravo I had a P0430 code (which is the same as a P0420 just different bank) I watched the upstream 02 sensors whle driving at 55mph and found that the sensor was lazy. Replaced the sensor and have not had the code since that was about 5k ago. A heck of a lot cheaper than the $1200 for a replacement pipe with the cats.
good luck
The Following User Says Thank You to tempfixit For This Useful Post:
Alphabravo (08-03-2011)
Old 08-03-2011, 08:37 AM
Thanks, Tempfixit. I probably should change the O2 sensors anyway, so I'll just change them first and then see what happens. I'll try the upstream sensor first. Thanks again.
Old 08-03-2011, 10:29 AM
coalminer coalminer is offline
Send a message via Yahoo to coalminer
I have seen the P0420 on 2 different caravans, one with about 100k and the other one with 225k and after replacing both sensors, the code went away and didnt come back. Funny how the computer thinks the converter is bad and not the sensors.....
The Following User Says Thank You to coalminer For This Useful Post:
Old 08-03-2011, 11:53 AM
rkvons's Avatar
rkvons rkvons is offline
My understanding of this is that when the car first starts and is cold, the computer sees that the readings of the before and after sensors track together (Part 1). Then, after the car warms up and the CAT starts doing its job, the reading of the two sensors diverge (Part 2). The efficiency test failure indicates that they are not diverging and implicates the CAT. I also heard that you can take an inefficient CAT off and soak it in a mild detergent and rinse it off good and put it back on and it may work fine after that.
The Following User Says Thank You to rkvons For This Useful Post:
Old 08-03-2011, 02:00 PM
Thanks for all the replys. I got a lot of good info. I'll start by changing the sensors first then post the results.
For Sale 2003 Honda Civic EX Coupe, 108k miles chelsevans851 Cars/Parts for Sale/Exchange 0 09-23-2010 01:26 PM
93 3.3 dies, runs four miles, dies, crank no start, ok in 2 hrs, for 4 miles Voyagenot Caravan | Voyager 9 06-10-2009 06:31 PM
96 1.3 LSi with a P0420 Code goinkster Metro 2 01-14-2007 04:22 PM
1997 GP, SE, 3.8 DTC Code P0420 (HELP) Byrd1js Grand Prix 2 02-22-2005 06:25 PM
FS: 2003 Altima 3.5 SE Black Low Miles, MANY EXTRAS Dave@ActiveTuning Altima 0 02-26-2004 01:49 AM
