Old 08-02-2011, 08:21 AM
jimmbb jimmbb is offline
Smile '90-'94 Chevy Lumina Headlight System
Okay, I am now an expert on this subject. I came here looking for help, but found others with same problem. -No headlights/no running lights. Ended up paying an "expert" on "JustAnswer"! Thought I'd share:
First: There are three fuses/breakers to check. 1) The 10amp in the glovebox. 2) The 20amp in the "component block" under the glove box. 3) The 50amp in the "breaker box" under the hood on drivers side.
Second: If these are good, don't go running out buying parts like I did. (There may or may not be a Headlight Relay; it's listed and I bought one at a parts place, but my expert says there isn't one. Wasn't one on the schematic either, but when I was done and plugged in the breaker, I heard the distinct clack of a relay somewhere!) Check for 12v on the two Drk/GRN wires going in to the Lightswitch from the component center. Also; 12v on the pnk/blk wire form the Turnsignal (Dimmer) Switch via the glove box. (Don't be fooled by erroneous small voltage readings; this happens in cars; look for a good 12+volts.)
Third: Go from there: If you don't have 12v on the pnk/blk, it's probably the Turnsignal Swtch. (You have my sympathy!) If you don't have 12v on Drk/GRN.s, (Like in my case.), start tracing back through ComponentBlock to the BreakerBox. (I found a corroded wire just under the breaker-box on the wheel well.) Of course, if you have all three 12v.s, it's probably the Lightswitch.
Hope this helps somebody!
Old 08-02-2011, 07:31 PM
maxwedge maxwedge is offline
A990 racer
Re: '90-'94 Chevy Lumina Headlight System
Good info, but the use of a shop manual and oe wiring diagram should have been sufficient to track this down.
Old 08-03-2011, 07:12 AM
That's nice. Just where do we lay our hands on a shop manual and whatever an OE is??? I've tried and only end up Yahoo at Repair Manuals where; for a price they'll send you one.
Old 08-03-2011, 11:35 AM
A990 racer
Correct, you have to buy one, what's the issue there? oe/ original equipment.
99 chevy lumina for sale or parts harleyrider98ci Cars/Parts for Sale/Exchange 1 12-19-2009 07:35 AM
1999 Chevy Prizm - Headlight bulb selection n1ckml007 Prism 3 10-26-2009 08:40 AM
'94 Chevy Lumina Euro 3.1L T vin code, Engine erratic Tkaynk Lumina 7 10-19-2007 08:04 AM
1995-2001 Chevy Lumina Headlights tblake Lumina 3 06-20-2006 07:27 PM
'94 Chevy Lumina Heater Problem propilot Lumina 6 01-08-2004 02:29 AM
Tags
headlight , relay?
