Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 08-01-2011, 04:25 PM
phipps phipps is offline
A/C Issue - Vacuum?
The AC in my 2000 Dakota is acting up randomly. I noticed it one day when I had it on Max and the air got warm. After a couple minutes it cooled back down.
Then the other day I had it on normal blowing out the dash when the air stopped blowing. At first I thought maybe it had frozen up but then I noticed the air was coming out the defrost rather than the dash. After a minute or so it started blowing out the dash again.
Are the mixer doors operated by vacuum? I was thinking maybe there is a leak causing the doors to not operate properly. Is my thinking correct? Where should I start looking?
Thanks!!
Old 08-01-2011, 05:45 PM
jpb53 jpb53 is offline
Re: A/C Issue - Vacuum?
They are vacuum operated. Vacuum is fed to the inside to the control head through a black plastic tube. There is a check valve in this line in the eng compartment so you either have a leak or the valve is bad.
Old 08-01-2011, 06:19 PM
Thanks!
Where on the firewall does the vacuum line run through?
Old 08-01-2011, 06:23 PM
Where the AC lines come through the firewall.
High quality used vacuum pumps? Sand3 Fabrication Tools 1 02-10-2011 07:59 PM
1997 LeSabre Vacuum Leak? nkmhockey LeSabre 3 12-10-2010 03:20 AM
96 Eclipse Rs Non-turbo Vacuum problem. donidavis Eclipse Problem Diagnosis 27 08-29-2010 09:07 PM
1987 F-250 351w Vacuum Hose Routing Ijustneedhelp F Series 0 07-04-2010 08:23 PM
need vacuum diagram:'88 ram d-50,mitsu 2.0 liter cukoobajube Ram Pickup | Ram SRT10 0 05-31-2009 05:59 AM
