Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 08-01-2011, 12:08 PM
tkswan's Avatar
tkswan tkswan is offline
Cruise control shut down
2002 LS V8.
Should a low fuel condition (or less that 1/4 tank) cause the cruise control to disengage itself.
-tswan
Old 08-01-2011, 12:18 PM
joegr joegr is offline
Re: Cruise control shut down
No, but a no fuel condition would.
Old 08-01-2011, 06:40 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Is this a common occurrence, or did it only happen once? Ie: does the cruise seem to work fine for 10 miles then shut off, or is it only when the tank is low that you have a problem?
-Rod
Old 08-08-2011, 11:40 AM
tkswan's Avatar
-Rod
apparently its happening consistently. This is happening on a 2000 year LS, Buddy of mine. I told him that it seems odd that the level of the fuel tank would shut off the cruise control, or maybe its the 50 miles to empty low fuel alarm is shutting it off electronically. I also thought the clock spring is starting to fail but all the steering wheel controls seem to be working fine.
I told him i would ask "the LS wise men" on this forum what they think.
-tswan
Old 08-08-2011, 01:42 PM
shorod's Avatar
SHO No Mo
I wouldn't rule out the clockspring.
-Rod
Old 08-08-2011, 02:21 PM
tkswan's Avatar
-Rod
yep. he told me that it shut down on him again while on the road this weekend. He had a 3/4 full tank. So the other incidents where the fuel was low was just coincidence but im betting clockspring is starting to fail.
-tswan
Old 08-08-2011, 04:45 PM
Things that normally do disengage the cruise control:
1. The off switch on the steering wheel. A bad clockspring could fool the electronics into thinking this switch was pressed.
2. The brake light switch. If just thinking about pressing the brake pedal can make the brake lights come on, this might be the problem.
3. The hydraulic brake pressure switch. This is a redundant safety cutoff for the cruise control.
4. Not enough engine power to maintain speed.
cruise control shutting off longslide Suburban 5 11-25-2009 08:23 PM
Cruise control freak out cobraprince 3000GT/Stealth 13 03-23-2009 10:41 AM
1998 Zx2 Cruise Control Problems ddppci ZX2 1 02-17-2009 10:59 AM
2001 Malibu and the Cruise Control shutting off. ddev Malibu 1 01-21-2008 03:41 PM
99 T&C cruise control kick-down panders25 Caravan | Voyager 0 09-25-2004 06:17 PM
