Old 08-01-2011, 11:25 AM
bayoudj bayoudj is offline
What lift if any for larger wheels
I have a 2008 2500 z71 that i want to put 20" or 22" wheels on. I do not want a 6" lift, so what is the minimum lift that I would need to support 22" wheels.
Old 08-01-2011, 04:01 PM
inafogg inafogg is offline
Re: What lift if any for larger wheels
you may not need to lift at all. i have (my dad) an 05 silverado with 20's
on it.plenty of clearance up/down & turning.
BTW he did'nt want them & went back to 17's so the 20's are 4sale cheap
wheels lugs,locks,center caps real clean crome over aluminum sell for
1000.00 each he wants 200.00 each (6 lug 2wh drive)
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 08-01-2011, 11:35 PM
4x4junkie 4x4junkie is offline
its possible to run up to a 265 70 tire.... without a lift on it, i currently have 275 60 20's on my 2000 chevy silverado 2500 4x4 (8 lug) and i had to install a leveling kit to give enough clearance for turning due to rubbing issues without it ... if you look on eBay for a leveling kit one can be purchased for about $150.00, they adjust your torsion bar setting to allow larger tires, (the larger tires will cause quicker wear on stock components like, wheel bearings, cv axles, control arm bushings tie rod ends) be sure to install the new shock mounting brackets to adjust for the difference in height ... most leveling kits will accomodate up to a 33 inch tires and maintain factory ride.... A WHEEL ALIGNMENT MUST BE DONE WITH ANY SUSPENSION LIFT INCLUDING LEVELING KITS.
4x4Junkie
2012 silverado 1500 ext. cab LT
Z71 4x4 with allstar package
5.3L V8 Flexfuel with 6 speed AT
Onstar / Sirius XM
Factory Tow Package
Electric Brake Controller
Silver Ice Metallic
265/65/18
Wifes Vehicle
2014 Kia Sorento EX AWD
3.3L V6
Toys
2007 Yamaha VStar Silverado
1086cc 45 degree vtwin
Grey and Silver
GPS positioning locator installed
Old 08-15-2011, 09:27 PM
more specific to the question. the lift required if any at all, will be determined by the entire overall size of the rim and tire... if the rims used and tire remain in the normal size range of the standard size tires that came stock on the vehicle no lift will be needed, if you use a tire equivelant to 33 inches you will most likely need a leveling kit. larger the overall tire size the larger the lift would be required.
4x4Junkie
Onstar / Sirius XM
Factory Tow Package
Silver Ice Metallic
265/65/18
Wifes Vehicle
3.3L V6
Toys
Grey and Silver
Pros/Cons of Upgrading to Larger Wheels Nav712 Tires and Wheels 1 08-15-2011 09:34 PM
Lift Kits on newer cars for larger wheels?? Is it needed? PROPROJECTS Wheels/Tires/Suspension 7 10-20-2007 01:03 PM
Need larger wheels for E55 AMG dharvey Tires and Wheels 0 10-18-2004 12:33 PM
What are the REAL effects of larger wheels if any on my 88 Accord??? 88LXi68 Tires and Wheels 0 02-17-2002 11:53 PM
What profile tyre for 17" wheels on an E30? EddScott 3 Series 1 02-07-2002 11:41 PM
