Go Back   Automotive Forums Car Chat > Mazda > MX-5/ Miata
Old 07-31-2011, 01:09 PM
miatamaze miatamaze is offline
2000 MX-5: Random misfires and P0420 code
This is my first Miata. Purchased it locally from it's second owner just 2 months ago. Only had 54,000 miles, so I figured it was barely broken in. The previous owner said he had just replaced the catalytic converter. After about 2 weeks, I noticed rough idling when first starting the engine. Then the CEL came on with "random misfire". Cleared the code and thought all was well. A few days later...happened again. After several repeat performances, there was a very bad episode were the CEL started flashing and the car could barely move itself. Now there is a very bad rattle coming from the exhaust and when you bang on the converter, it sounds like there is a big rock loose on the inside. From all the reports I've read I think it needs a new coil pack. The previous owner replaced the crankshaft position sensor and installed new NGK plugs and wires before the new converter. I have purchased a new coil pack and will soon attempt to replace the old one.
Does anyone think this is my best option?
Old 08-11-2011, 02:00 PM
Docbass Docbass is offline
Re: 2000 MX-5: Random misfires and P0420 code
I would first run a compression test just to be sure you have not burned some valves or a piston has a hole in it. Then do a wire and plug change then if the problem is not resolved then do the coil packs.
Then look at replacing the cat again
Let us know what you find to be the problem
96 miata blk/blk 96 miata montego blue
1998 grand prix GTP 3.8L V6 supercharged, random misfire gtpmaddi Grand Prix 2 04-19-2011 08:16 PM
2000 se po300 random misfire charlie40 Grand AM 2 12-25-2010 09:19 AM
02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6 osuyaqui Dakota 3 04-09-2009 08:49 AM
96 Z34 Multiple/Random Misfire and exessive gas consumption poppyrodregues Monte Carlo 3 04-13-2008 10:33 AM
Would bad crank sensor cause random misfire and rough starts? MeanWS6 Engineering/ Technical 1 05-07-2004 09:20 AM
