Old 07-30-2011, 09:34 PM
Brent S Brent S is offline
Front Stabilizer Bar - 99 GTP
My front stabilizer bar is cracked at one end.
I was wondering what the difference is between the GMPP offered by ZZ Performance and the suspension kit offered by GM, # pk12456148.
Any info or advice welcom.
-Brent
'99 GTP
Old 08-02-2011, 11:10 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
Re: Front Stabilizer Bar - 99 GTP
the GMPP is thicker,stiffer, and stronger. i got one when my stock one cracked. if you do get the GMPP one, it requires a little more manipulation to get it in. we gently jacked up the downpipe from underneath the car with a bottle jack so that the bigger bar would slide in.
2000 Grand Prix GTP Daytona: 4k original miles
1997 Pontiac Grand Prix GTP bought with 68k, sold with 112,000, and i loved every mile
2011 Subaru Legacy 2.5i (daily driver)
1973 MGB
Old 08-03-2011, 10:58 AM
Thanks for the tip!
I noticed past posts regarding an issue with the brackets; I ordered #12498643 from GM, and it comes with bushings, but it doesn't look like it comes with brackets.
Should I expect a problem with using the stock brackets?
-Brent
'99 GTP
Old 08-03-2011, 11:14 AM
TDWPgtp's Avatar
hmm i dont remember having any problem with any brackets... i could be wrong, however. maybe someone else will have some input on that
1973 MGB
Old 08-03-2011, 11:22 AM
I thought you mentioned something here:
http://www.automotiveforums.com/vbul...d.php?t=963014
-Brent
'99 GTP
Old 08-03-2011, 11:32 AM
TDWPgtp's Avatar
oh wow. good call. upon reading that thread, i seem to remember having to buy a socket with a universal joint so i could tighten one of the bolts down.. and as far as the brackets go, i think i may have just elongated them with a drill just enough to get them to fit. again, obviously my memory isnt spot-on, so i could be wrong. i hope i helped at all
1973 MGB
Old 08-03-2011, 11:42 AM
Yeah, I just noticed that your post was back in 2009, and "rubberman" just posted in it, in June 2011.
He or she claims you need new brackets, as well as bushings.....but, maybe that's wrong, since the GM kit only comes with new bushings.
-Brent
'99 GTP
Old 08-03-2011, 01:40 PM
TDWPgtp's Avatar
ya come to think of it im pretty sure i just drilled out the brackets just a little bit to make them fit. i did order polyeurathane endlinks, however, as was recommended to me by one or two of the other members. i believe the brand was MOOG.
1973 MGB
Old 08-05-2011, 07:42 AM
Well, the new bar is in, but the stock brackets do seem to be causing an issue. They seem too small. They're already fairly tight, and I still have approx 1/2" gap between the flange on the bracket and the frame.
Is there a larger bracket that I can get, which will fit better with these new/larger/solid stabilizer bars & bushings???
-Brent
'99 GTP
front stabilizer bar Green97 Grand Prix 14 08-07-2008 12:12 PM
Front Stabilizer Bar broken rbsteve Grand Prix 2 06-21-2007 01:29 PM
Cracked Front Stabilizer Bar 1999montana Montana/Montana SV6 0 06-18-2006 08:36 PM
front stabilizer bar brushing ngsiufung Camry/Camry Hybrid/Vista 2 12-07-2004 10:14 AM
