Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-30-2011, 11:06 AM
kkaupang kkaupang is offline
Question 03 Sierra Fuel Pressure
I have an 03 Sierra Half Ton when the engine is warm it runs fine
but at cold start, half the time it doesn't have the fuel pressure to start, i have to turn the key a couple times to build it up. idk if the fuel pump is weak for if it would be more the regulator
i started having this problem after i replaced the fuel pump.
the fuel pressure gauge shows 50-55 lbs, but every now and then when its cold it will only jump to around 5 lbs (but this is only when the engine is cold... why?)
What should i go after first? Regulator, new pump, Replace the fuel filter again?
Thanks
Old 07-30-2011, 12:54 PM
maxwedge maxwedge is offline
A990 racer
Re: 03 Sierra Fuel Pressure
Pump. and check for a burnt connector at the tank.
Old 08-10-2011, 11:09 PM
Fuel Pump ended up going out on me the other day, New Airtex Fuel pump, new fuel filter, and new wire harness for the pump. Now she runs Great!
Reading high fuel pressure (carbureted) caffeineaholic Caprice 16 09-25-2010 03:55 PM
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 07:32 PM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 10:09 AM
fuel pump pressure specfications dieter LeSabre 7 07-29-2009 03:05 PM
97 Blazer low fuel pressure new pump stalls in gear ChevyFamily Problem Diagnosis 6 06-05-2009 07:12 PM
Tags
fuel , low , pressure , regulator
