Go Back   Automotive Forums Car Chat > Chevrolet > Uplander
Old 07-29-2011, 02:03 PM
Simplicity4041 Simplicity4041 is offline
All-Wheel Drive Disabled
My 06 Uplander has the "AWD disabled" light on. From what I have read it is probably the differential check valve that is bad. I just changed the very expensive fluid and do not want to drain it to replace the valve unless it is necessary. So my question is can I just plug in a known good check valve to see if the fault clears, without actually installing it in the differential?
Thanks for any input.
all wheel drive is hopping on pavment like its in four wheel drive on sharp turns kenevile333 Explorer | Explorer Sport Trac 0 04-18-2008 05:55 AM
convert all wheel drive to a 2 wheel dive john1962 Engineering/ Technical 3 05-03-2007 11:27 AM
all wheel drive disabled polarisxcr Rendezvous 3 03-08-2005 08:19 AM
all wheel drive or front wheel drive? tran_nsx Integra 7 11-01-2003 09:58 PM
XT Turbo All Wheel Drive DMC12 General Discussion 4 06-04-2003 02:43 PM
