Go Back   Automotive Forums Car Chat > Mazda > MX-5/ Miata
Old 07-28-2011, 02:52 PM
Docbass Docbass is offline
Read before posting
Please if you have a problem do not post it under someone elses post unless it is the same problem. 1 your post may get over looked 2 It may prevent the first poster from getting a problem solved
If someone has a post my lights do not work ,do not reply with I have same problem my car overheats or I have a problem my car over heats. Neither has anything to do with the headlight not working. Start a new thread and put My car overheats then if someone else has same problem they can post in your threaad mine does too
If you have a problem please put in your post the year of the car,this helps narrow some problems down.
It also helps knowing what you have done to fix problem.
Just because you are new or unfamilair with car repair or a girl do not let that hold you back . you can do the work with a little guideance and a couple of good repair books
Hope this helps I will try to monitor a littel more often and give what help I can
Old 07-28-2011, 03:08 PM
Re: Read before posting
bump
96 miata blk/blk 96 miata montego blue
4th Gen FAQ - If you are new, please read before posting Setanta '88 - '91 Civic | CRX | Wagon | Shuttlee 33 07-01-2008 01:49 PM
240sx FAQ: READ BEFORE POSTING, NEWBIE!!! J SPEC SilEighty 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 88 08-27-2005 09:39 PM
Read before posting in "Introductions" forum. Shortbus Introductions 0 12-27-2003 10:15 AM
Please read before posting. HiFlow5 0 Mustang Talk 0 06-29-2003 04:01 AM
