Go Back   Automotive Forums Car Chat > MG > MGB
Old 07-27-2011, 05:32 PM
stocksbonds stocksbonds is offline
mgb runinng bad
Let me try to explain this again, when i start the car in the morning it starts just fine. Runs great for about 20 miles. after that the car starts to spit and sputter and tries to stall. when it does stall, i have to wait for it to cool down before i can start it again. the Carburetors are too hot to touch. it has an electric fuel pump so i don't think this has anything to do with the problem. it also has an electronic ignition which may be a problem or it may be a distributor problem. i don't know where to start or what to do to remedy this. After taking out the single Carburetors with the automatic choke and replacing it with duel SU carbs from a 1963 the problems still occurs. any opinions on where i should start would be helpful.
Old 07-27-2011, 05:41 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: mgb runinng bad
G'day,
Nothing like an old MGB to give problems
Has it still got the condenser and resistor based ignition and distributor, or has the electronic unit replaced it?
Old 07-28-2011, 06:34 PM
Re: mgb runinng bad
Originally Posted by Moppie View Post
G'day,
electronic
Old 07-28-2011, 11:22 PM
Moppie's Avatar
Master Connector
Re: mgb runinng bad
Originally Posted by stocksbonds View Post
electronic
Assuming it's not over heating, then it sounds like the electronic ignition has failed.
As it warms up, there is very slight expansion in either the ignitor module, or the points module, which is enough to cause them to fail.
Once cool again, the problem goes away as the parts shrink slightly.
Do you have an old set of points and coil you can put on it to test it?
Old 12-19-2011, 04:58 PM
tractorat tractorat is offline
Re: mgb runinng bad
What kind of gas are you running ? If you can find some, try a full tank of gas without ethanol. Look at the web site www.pure-gas.org to see where it might be available in your area. I experienced the same symptoms you were with my 74 mgb. With the alcohol free gas, it runs just as well as it did when brand new.
Speaker location 1978 MGB funstond MGB 2 07-04-2011 10:07 AM
Does my 1973 MGB require LEAD or NO-LEAD? hooverbean MGB 1 06-19-2010 05:45 AM
MGB Summer Cooling mikelaw MGB 0 03-19-2010 08:42 AM
How much is a 95 3.0L Voyager With 95k & Bad Tranny Worth? LightShifter Caravan | Voyager 2 05-30-2009 09:19 PM
