Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 07-25-2011, 09:00 PM
avmx avmx is offline
Lost comm with Transfer case module
2007 yukon obd dtc u0102. lost comm with xfer case module. symptoms are: no 4x4. No power mgmt (V8 to V4). very subtle difference when it shifts between gears. Indicator light on knob is off. The problem is intermittent, everything will start working after driving for a while. Once I shut it off and restart, the problem comes back. Anyone have any ideas? Also, where is the transfer case module located?
Old 07-26-2011, 09:34 AM
jyount jyount is offline
Re: Lost comm with Transfer case module
Goto autozone.com and lookup the schematics for it. Sounds like a power or ground issue to the transfer case module. Possibly the com wire has an intermittent short or open too. I worked with a 2003 vette that had intermittent module codes and chased that thing forever. Finally figured out that the entire harness was pinched between the seat mount bracket and the body. Electrical problems are usually pretty simple in nature. Learning how to diagnose them is 99.9% of the battle.....
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 05-31-2012, 09:54 PM
Turned out to be a bad transfer case module. $400...ouch.
89 K-5 with a tranny/transfer case problem curtisserrano 1969 - 1994 Full size 7 06-01-2010 08:14 AM
Transfer Case Module Part Number Cujster Problem Diagnosis 3 07-27-2008 08:47 PM
'99 Suburban Transfer case module & dash gillyIR Suburban 3 02-02-2006 04:56 PM
transfer case module myjimmy Blazer 3 02-01-2006 11:24 AM
Transfer Case Module myjimmy Jimmy 3 01-31-2006 11:39 AM
