Old 07-22-2011, 05:04 PM
applevalgal applevalgal is offline
a/c problem
My room mate has a 1998 buick Park Ave. Last week he had to replace the starter. Everything went well except now hot air comes through the vent on the driver's side when running the a/c. All the other vents run cold. Any suggestions what the problem may be?
Old 07-22-2011, 08:48 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: a/c problem
I assume you disconnected the negative battery cable before replacing the starter? Did you also you turn OFF the A/C control unit before disconnecting the battery?
Old 07-23-2011, 07:52 AM
procaddytech procaddytech is offline
Re: a/c problem
Turn the ignition to the "ON' position for 3 minutes to recalibrate the A/C actuators for proper travel. If that doesn't work the driver side temp actuator mave be faulty or traveled out of range.
The Following User Says Thank You to procaddytech For This Useful Post:
applevalgal (07-23-2011)
Old 08-02-2011, 07:04 PM
walt03 walt03 is offline
Re: a/c problem
I assume that the AC control is on AUTO and key is ON for three minutes or longer.
What if this doesn't work?
Old 08-03-2011, 05:22 AM
Re: a/c problem
Copied from service info (any setting should be ok, just don't change any settings during the 3 minutes, key off after before starting):
Important: After the actuator has been replaced, the actuator must be recalibrated for proper travel. The ignition must be cycled on for 3 minutes in order to allow the programmer and the actuators time to recalibrate for proper travel.
If the right panel vents are "cold" and the left are "hot", the left teperature actuator is out of calibration or failed. If the right is cold and the left is just less cold or warm, the A/C charge may be low. Remove the left sound insulator and watch the center of the actuator as you cycle the the driver's temp from 60 to 90. Auto setting will be fine because at 60 & 90 the system is out of Auto control and is full cold or full hot. After a few seconds the center should turn (there is a notch cut in the rotating part of the actuator that come close to lining up with 2 marks on the actuator body) from stop to stop. If it doesn't move give it a little tap, it may start working. If not, unplug it and remove it and turn the door by hand and verify that it moves freely and changes from hot to cold. The driver temp actuator is the left actuator in the illustration and the mode actuator is the other. The 1's are just pointing to the screws. Try the calibration first. You may need to disconnect the battery again to erase the programmer memory, reconnect it and then key on engine off for 3 minutes.
Nissan Cefiro - Idling/driving rpm problem fnasir Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 10-01-2010 10:35 AM
01 Silverado Tranfer Problems kash1235 Silverado 0 04-14-2009 05:44 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
