Old 07-22-2011, 03:27 PM
Shadow Spirit Shadow Spirit is offline
Power Window Relay
I have a 95 Buick LeSabre Limited and I was wondering if anyone could help me.I have been trying to locate where the power window relay is.Any help would be appreciated
Old 07-22-2011, 10:54 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Power Window Relay
Which window? Do you have express down on the drivers side?
Old 07-22-2011, 11:13 PM
Actually it is all windows.I replaced the master switch with a used one and the front windows worked fine for a couple of days and then quit again.Yes I do have express down on the driver's side.
Old 07-23-2011, 11:55 AM
HotZ28's Avatar
AF Moderator Elite
If all windows are having the same problem, you could have either a ground problem, or circuit breaker problem. Can you here the relay's clicking in the door when the switch is made? BTW, the express down function has an electronic module that serves as both a relay & controller for the drivers side (express down) window. The other windows use a regular relay, and all of those are located behind the door panel next to the window motor. It would be highly unlikely that all the relay's are at fault. Do you currently have any signs of wet carpet on the drivers side floor?
Old 07-23-2011, 01:33 PM
procaddytech procaddytech is offline
The only relay in the power window sytem is in the express down module. All of the other door windows get power from the master switch, through each door's individual switch and directly to each motor. If you use express down and the relay sticks it will cause the cicuit breaker to open rendering all other windows inop. Be careful, but you can touch the power window circuit breaker and if it is hot, I would recommend unplugging the express down module. (You will have to remove the door panel) The driver window will not work, but if it is part of the problem the other windows should work. Schematics below:
http://i36.photobucket.com/albums/e5...r/Windows1.gif
http://i36.photobucket.com/albums/e5...r/Windows2.gif
There are no signs that the driver side floor has been wet.I bought a used master switch and the windows worked fine for a couple of days and then started doing the same thing.I traced all the wires and nothing seems to be shorting out.
Old 07-23-2011, 06:08 PM
happydog500 happydog500 is offline
...Can you here the relay's clicking in the door when the switch is made?
Don't want to hijack the thread, but I have a problem with one of my windows. Mine clicks, what's the difference if you hear the a click or not?
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 07-23-2011, 10:04 PM
HotZ28's Avatar
AF Moderator Elite
Chris.
Which window are you talking about? If it is the drivers side, and you don't here the relay "clicking" (unless you are hearing impaired) then the relay (module) is not responding to the switch, or the module has failed. This problem could be be traced to a ground problem, module, window motor, or the switch.
Old 07-24-2011, 09:39 AM
imidazol97 imidazol97 is offline
AF -Advisor
A break in the brn wire to C1 on the switch plate where the door flexes it opening and closing would cause loss of power to all windows as I read it. Pull it switch plate and check for power at C1 while moving the wires in the door tube, e.g.
Also the ground at C200 could be the problem. Does anything else inside the car not work right when the power windows don't work? Lots of things use the C200 ground on the driver's door sill area. Those can be corroded..
Old 07-26-2011, 12:16 AM
Mine is the drivers side rear. I hear it click but it doesn't open. Boy am I glad it quit when it was closed.
Chris.
New Balance 662
Trek 8000
Old 07-26-2011, 11:42 PM
HotZ28's Avatar
AF Moderator Elite
Chris.
You need to remove the door panel and look inside to see what the problem is. More than likely, you have a bad regulator on that window.
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 02:44 PM
power windows stopped working - 2002 Mercury Mountaineer hoehring Mountaineer 2 01-18-2010 10:25 AM
Power Windows Elec Prob. Please help!! dlane85 Corsica 1 07-29-2009 11:37 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 07:13 PM
98 power window express down problem fliplover Monte Carlo 1 04-03-2009 12:48 PM
