Old 07-21-2011, 01:23 PM
jtippett10 jtippett10 is offline
AC cold then hot
1998 jeep cherokee 4x4 limited 128k. AC gets cold rather quick, but every ten minutes or so, the AC will blow hot for 10 minutes, then return to cold air again. I thought that it needed freon, so I hooked up a guage and freon to fill it up, but it reads overcharged on the guage. I live in las vegas, so even ten minutes without AC is miserable. Going on a trip with kids and want to make sure AC is working all the time. any ideas are helpful. thanks
Old 07-21-2011, 07:44 PM
rhandwor rhandwor is offline
Re: AC cold then hot
If your over charged I think a safety switch is shutting off the compressor. Look at the clutch on the compressor is it shutting on and off with the temperature change.
Depending on your tools charge enough to get a good sweat on the suction line on a hot day.
Get a loaner set of gauges and check both suction and discharge pressure.
Old 07-25-2011, 09:07 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Once you have the pressure correct, let us know if the problem continues.
If it does then there may be a vacuum leak that is causing the changes in the system.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
A/C cold then hot Andy-C Yukon 2 06-28-2009 03:45 PM
'97 Park Avenue - passenger heat goes cold then hot then cold, etc. kawal Park Avenue 9 03-05-2008 08:30 PM
AC/Heater...blows cold then hot Atlanta2112 Problem Diagnosis 3 03-11-2007 09:01 PM
AC blows cold, then hot, then cold... sebryce Blazer 15 05-06-2006 04:15 PM
2004 ac cold then hot tnmh '01-'05 Civic 3 11-09-2004 11:25 AM
