Go Back   Automotive Forums Car Chat > Nissan > Older Pickups
Old 07-21-2011, 01:57 AM
Pdx88lude Pdx88lude is offline
1985 720 4x4
So, here is the deal. I worked my a$$ off to get this truck running finally got it going great after rebiulding the carb and all kinds of stuff to find out that it was only a vac line that was tore on the advance on the dist, So I had it running great I previously broke a holder bolt for the dist, So after i got it going great I was going to pull the bolt out that was busted so in order to get it out I had to pull the dist out, I put it right back in and now it will not start. I have set everything TDC and made sure it was pointing at #1 and still wont run have checked all wires on cap tested have spar all the way to the spark plug but it wont start, Also it is getting plenty of to test it to see if it would start with starting fluid didn't work. I am about to just say screw it and drive my lude again. Any Advice? Thanks Guys
1985 720 nissan dmickeysmith Older Pickups 1 11-05-2010 07:36 AM
1985 720 no power in 4th or 5th natecs Older Pickups 1 09-24-2010 10:52 AM
1985 720 z24 carb need picture of distributor cap and wires borninabarn Older Pickups 2 03-30-2010 08:22 AM
240sx in a 1985 720 pickup radsterz34lover Older Pickups 1 10-08-2005 07:09 PM
85 nissan-datsun 720 4X4 nose-gobblin General Discussion 1 04-23-2005 06:26 PM
