Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-19-2011, 10:09 PM
kevo13 kevo13 is offline
97 Sierra Backfiring
First post...Blew intake manifold gasket and took it to a shop for a repair.
Mechanic called and said the two screws in the distributor rotor were just bouncing around inside so I said replace it.
got the truck back and it is backfiring through the intake and running crappy at about 2500 rpm .
I took the distributor cap off and the rotor turns maybe an 1/8'' each way could it be the distributor ?
Old 08-01-2011, 04:34 PM
phipps phipps is offline
Re: 97 Sierra Backfiring
Replace the distributor. Your worm gear is worn.
Old 08-08-2011, 09:27 AM
ken_man_1 ken_man_1 is offline
Smile Re: 97 Sierra Backfiring
You can also replace just the gear. It's not that expensive, and the dealer has it on hand more than likely. I did this a year ago on a 98 (5.7L), and cleared up the problem. The gear was so bad you could cut paper with it. The teeth were just on the edge of breaking.
88 K1500 5.7 sputtering, backfiring occasionally dirkhood C/K 17 01-30-2011 11:11 AM
1974 Dodge 360 W100 Backfires jb77 General Discussion 0 08-28-2010 07:23 AM
93 suburban backfire cjttmyers Suburban 13 07-12-2009 10:46 AM
1991 Chevy 454 backfires, runs good, backfires, sometimes cycles pjksr1955 C/K 15 04-03-2009 10:59 AM
1999 4.8L Sierra sluggish Backfiring Operator4100 Sierra 2 07-08-2008 08:09 PM
