Go Back   Automotive Forums Car Chat > Lincoln > General Discussion
Old 07-19-2011, 12:14 PM
c.grant99lincoln c.grant99lincoln is offline
Can't find his dang coolant leak
Okay 99 4.6 v8 heater not blowing hot air, coolant is leaking down engine behind the pulley on bottom? What should I do?
Old 12-19-2013, 06:01 PM
acarinneed acarinneed is offline
Re: Can't find his dang coolant leak
Not a mech, but I bet if you trace the leak it'll end up at the water pump. The hole on the bottom leaks when the pump needs replacing, but the fluid will follow the block down to it's final drip point - which, in your case, may be behind the pulley. Good luck!
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
Astro- Help me find/fix my coolant leaks. Funk-O-Meter M Bodies 5 06-08-2008 06:29 PM
