Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 07-18-2011, 06:50 PM
c.grant99lincoln c.grant99lincoln is offline
Coolant Leak 99 continental
Ok so i have this 99 continental and i had a front bearing go about 8 months ago. i let it sit well i used my other car for a good 6 months till i finally got around to getting it fixed. So when i got my car back i noticed that it was leaking coolant from around the res. tank cap (a lot once the engine was warmed up with the ac on) so i let it cool off then opened the cap and turned the engine on and let it warm up cause i thought there was air in the system which i think there was cause the coolant level kept going up and down significantly till all the bubbles stopped gurgling up, so i turned it off and let it cool down filled it to the cold fill line put the cap back on and it hasnt leaked since from the cap but i discovered a leak from somewhere around the crankshaft pulley. so what do i do next?
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 06:43 PM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
